What 4x100 wheels will fit e30s?
  • Alpina
    • Oct 2004
    • 838
    #136
    I Have 17x 8.5 front ((215/40)) and 17x 10 ((245/35)) rear
    pics------>> http://www.bmwkraftur.is/spjall/viewtopic.php?t=16589
    Sveinbjörn Hrafnsson
    E30 CABRIO V12 M70B50 ///
    ALPINA B10 BITURBO 346 @ 507
    E34 550 V12 JML
    Finnish wisdom : If you want to Win,, hire a Finn
    http://alpina.123.is/pictures/
    • Mike325
      • Mar 2006
      • 3685
      #137
      Sex.
      Originally posted by Kershaw
      • browntown
        • Jun 2004
        • 3524
        #138
        I have no idea what these mean but they look like compliments:
        Mjög svalur
        Svalastur!
        Gullfallegur!
        • Alpina
          • Oct 2004
          • 838
          #139
          Mjög svalur------- very COOL
          Svalastur! COOLEST
          Gullfallegur!
          Beutyful
          E34 550 V12 JML
          • e30cbe
            • Jun 2007
            • 46
            #140
            Originally posted by kylebes1
            ours are 35mm offset right?
            if i'm not mistaken 35 mm offset with 6 x 14 s , 24mm for 7 x 15s bear in mind offset in relation to wheel width gives actual placement on the car
            • steinbachphoto
              • Aug 2007
              • 914
              #141
              Will these work with my car?!
              17"x7" TSW wheels and 205/40ZR17 Falken Ziex ZE512 tires
              and i have no idea about the et_ _ stuff.
              http://www.steinbachphoto.ca
              • atomic
                • Jun 2007
                • 5691
                #142
                You need to ask you question here http://www.r3vlimited.com/board/showthread.php?t=83125 and will have to provide the et information to get an answer. The et is the most important information regarding fitment period.... Depending on et will depend on spacers etc.... So get more information together and post at above link and Jay will get you and answer or just read the thread and it has probably already been answered....
                • ctbimmer
                  • May 2007
                  • 6
                  #143
                  Another option some of you might want to consider is Team Dynamics PR1.2 or PR2, in 15x7 ET15 offset. These will take 205/50 pretty easily, and 225/50 might require rolling the fenders a bit. The 225/45 I haven't tested.
                  The TD wheels have the correct hubcentric fit, and do not require centering rings. They can also be used with stock length wheel bolts.
                  Most TD wheels are sold in ET25, so these ET15s sit a bit farther out, eliminating the need for spacers. [Edit: My point on the ET25 wheels was that many racers choose to run spacers to push them farther out...The ET15 achieves the same effect naturally.]
                  The rears tend to be toughest to fit, and lowering (even with stock LCA bushings) provides enough negative camber to get them to squeeze inside the wheel arch.
                  Chuck Taylor
                  NASA-SE SpecE30 Racer #218
                  • JRKOUPE
                    • Dec 2004
                    • 3159
                    #144
                    15/7 et 25 should not need spacers...I run K1's, et 27...15/7 ...w/ 225/50 15.......no spacers.
                    • viali8
                      • Nov 2005
                      • 673
                      #145
                      wheels
                      I am currrently looking at a set of wheels that are 15/7 ET27. Do you have any problems with the tire rubbing against the strut housings? How close is the tire to the strut housing. Thanks Matt
                      • JRKOUPE
                        • Dec 2004
                        • 3159
                        #146
                        superduperclose!>>>>>>Toyo RA1's are fat.....but I track car w/ no issues. I imagine w/ some cars and sagging components it could be a minor issue. But a thin frt spacer would do it........Massive Lee has nice affordable pieces....and he makes nice things.
                        • viali8
                          • Nov 2005
                          • 673
                          #147
                          thanks!
                          • e30eu
                            • Mar 2014
                            • 15
                            #148
                            Hi! Im quite new with e30 and looking for some help to be sure. Have searched forum and seen similar but not exact same type...
                            Does these wheels fit under e30?
                            Front 16x8" ET25 (with 215/40 tyre)
                            Rear 16x9" ET20 (with 225/40 tyre)
                            Hope you can help me guys,
                            Thank you
                            • gtdragon980
                              • Jun 2008
                              • 1808
                              #149
                              Thank you
                              As long as it has the correct center bore, I believe the only thing you will need are spacers. I am not too certain of the size for the spacers but I believe 10mm should suffice.
                              FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
                              Originally posted by scabzzzz
                              I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
                              1989 325i - Project/weekend driver
                              2002 325i - DD
                              2005 Suzuki SV650 - Toy
                              • e30eu
                                • Mar 2014
                                • 15
                                #150
                                Thanks gtdragon980.
                                Just one question more because if there is not the 8" wide wheels anymore left in stock, does the 16x9" ET20 (with 225/40 tyre) fit also in front? Or need the spacers then?
