What 4x100 wheels will fit e30s?
  • volgapower
    • 161
    #121
    who can tell me what means ET35??? whill that fit my car?
    • Jand3rson
      • 37587
      #122
      That's the offset of the wheel. And you'd need spacers to fit that wheel to your car properly. It will also have to have the correct centerbore.
      • volgapower
        • 161
        #123
        the centre bore (the hole in the middle) is a bit bigger, but they fit perfectly in the rear, but i didnot try to put them in the front, anyway what size spacers will i need???
        these are ENZO wheels 7J 15' ET35 front
        and 7.25J 15' ET35 rear...
        • Thumper
          • Oct 2006
          • 25
          #124
          I'm looking at some rims 15 x 7 et30 and wan't to run 225/50's I've read one person said it SHOULD be ok but before I spend the money (I don't want spacers) I would like a second opinion. I'm running tokico struts and springs. Thanks
          87' 325e (tokico struts and springs, Vines custom short throw shifter, 3.25lsd, blaster 2 coil, k&n air filter, and a 3.25i instrument cluster)
          • JRKOUPE
            • Dec 2004
            • 3159
            #125
            et 30
            You are taking a risk here...esp w/ frts. I run et 27 on 15/7 w/ 225/50 and I amthisclosetomyfrtstruttubes! You may also be close to your rear inner fender area.....it could work...but its a risk.
            • Thumper
              • Oct 2006
              • 25
              #126
              Thanks. It looks like you are more lowered than I will be though so not sure about the inner fender on the rear. Worst case scenario on fronts is I can grind the perch alittle bit to make room. My guess it might rub under hard cornering. Any other opinions?
              • Digitalwave
                is a poseur
                • 6293
                #127
                It wouldn't hit the perch, it would hit the strut tube itself, and you don't want to be grinding that down...
                RISING EDGE
                • Thumper
                  • Oct 2006
                  • 25
                  #128
                  DOH! Sorry new to e30's so it will be definetly be below the perch but might hit the tube and why can't I cut into that :jk:
                  Well I hope I don't need spacers. If so though atleast only the 5mm ones. Thanks
                  • Digitalwave
                    is a poseur
                    • 6293
                    #129
                    There's nothing wrong with spacers (besides the cost).
                    RISING EDGE
                    • Thumper
                      • Oct 2006
                      • 25
                      #130
                      Ehh its added weight 0.001lbs and it makes the wheels more likely to be unbalanced. Plus puts more load on the wheel bearing and lug nuts. I know not much difference but this will be a semi-track car and the little things add up.
                      • JRKOUPE
                        • Dec 2004
                        • 3159
                        #131
                        I agree to the pt I prefer to not run spacers on a track car....just one less thing to worry about but yet Im ok w/ K1 "rings". I agree w/ what you say
                        but many many Porsche cars...race cars..... use spacers. Maybe you should consider another wheel???????
                        And if you are going to track...consider using studs.
                        • Thumper
                          • Oct 2006
                          • 25
                          #132
                          Thought about getting a different rim but no mos deniro(sp) no money, and i'm getting a fairly good deal on these. Unless someone else has a lightweight 15x7 or wider rim they want to sell? Definetly going studs. Makes it easier to put back on also.
                          • backtrail69
                            • Jul 2005
                            • 4471
                            #133
                            I am running the rota slippys 16x8 et 20 with 225/45s I had to roll the rears because my car squats with teh boost :D! and the fronts hit on full lock countersteering....I need to roll teh fronts too. I have 215/50s on ronals 15x7.5 et 25ish on my DD and ive NEVER hit a thing even autoxing.
                            :: PNW Crew ::
                            '87 325 4dr, '74 2002
                            • SpecM
                              • Oct 2005
                              • 4531
                              #134
                              -How about 16x7 et40 rotas w/ 205mm tires?
                              1989 cirrisblau-metallic 325i
                              • Digitalwave
                                is a poseur
                                • 6293
                                #135
                                With 10-20mm spacers, sure.
                                RISING EDGE
