DIY - Walbro 255 fuel pump retrofit.
Please define loud...
Also, what kind of sound deadening/interior is still in the car?
Sent from my iPhone using TapatalkComment
higher pitched whine, almost like a whistling noise. also its a vert so the only things between the cabin and the fuel pump is the metal plate and my rear seat.Comment
Has anyone else had to put a slightly larger fuse in the fuse box for this pump? A friend and I both put these in and started popping a fuse for the pump. It was fixed by dropping in a fuse that was one step larger than stock.
Anyone else have this?Comment
Estoguy
Need a photographer, come visit my site: http://estoguy.wix.com/unique-perspectivesComment
I went back to the OEM pump. Following this DIY introduced starvation issues at AutoX events and mountain road carving anywhere below about half a tank.
The pumps themselves are great, though IMO they should be used by folks who can fab up a better way of mounting them in the tank than simply bending the rod from the OEM assembly.Comment
Bam, right on with the starvation.
This is yet another reason why I prefer early model e30's for track shenanigans. The fuel tank pump that feeds the external pump makes hooking up a Surge tank easy as cake since everything is there already. I grabbed a 1 liter inline unit from 034motorsports.
Yup, I swapped out my stock pump for the TRE version and now I'm suffering from fuel starvation at the track....Now I've gotta decide what is easiest and cheapest.Bam, right on with the starvation.
This is yet another reason why I prefer early model e30's for track shenanigans. The fuel tank pump that feeds the external pump makes hooking up a Surge tank easy as cake since everything is there already. I grabbed a 1 liter inline unit from 034motorsports.1991 318is sold!
1989 325=track car--S52'd
Durango R/T for towing.
>>>Build thread<<<
M235i daily driverComment
