Cheap fix for brittle crank sensor connectors
  • 94530inh
    • 66
    In the middle of a 1983 633CSI engine swap and my crank sensor connectors crumbled during disconnection. I fought with the idea of buying two new sensors $$$ - but decided to see if BMW sold the connector separately. They only sell the female connector. I popped it into Mouser and then was able to find "compatible products" and found the male connector. Price for two of the connectors was under $20 delivered to my door.
    https://www.mouser.com/ProductDetail...EvnkuR1Q%3D%3D
    Here are some photos. -- Hope this helps!
    65k 325i Automatic
    1985 M635CSI Frank Fahey Stroker
    1970 BMW 2002 (in restoration)
  • S.J.1981
    • Dec 2018
    • 116
    This brings back a lot of memories working on my Porsche 944 Turbo, those engines run really hot (open the hood and you receive this gush of heat it is silly) and yes, the majority of all connectors for the engine hardness just crumbles in you'r hands before attempting to even disconnect them.
    Especially on the rear of the engine at the bell housing, two sensors there, reference sensor and speed sensor, either will cause a crank and no start issue.
    Interesting that BMW does not sell the male plugs, Porsche stocks both male and female plugs and boots in vast quantities (for obvious reasons). Appreciate the link, sure will be useful for anyone down the road wanting to rebuild the harness or find replacement.
    • McGyver
      • 4636
      Ahhhhh, you're falling into the hole of connector plug part numbers. I've spent hours over the past few weeks trying to make sense of everything. At a high level, these connectors are all made by TE Connectivity. The correct connectors are Junior Timer, but some of the connection types are not available as a Junior Timer. In those cases, Junior Power Timer connectors will work. TE has a 'Datasheets & Catalog Pages' document called, "ENG_CS_889759_3_Timer_Interconnection_System_ _071 2" This will help to identify part numbers, but many are NLA and superseded. Here is my In-Process connector chart:
      5-Pin 4-Pin 3-Pin 2-Pin
      "Male" Plug ASSY 5 POSN JPT TAB Junior Power Timer 444208-1 CONN PLUG HSG 3POS Junior Power Timer 1-962581-2 CONN TAB HSNG 2POS FASTIN-ON Junior Timer 106462-1
      "Female" Plug 5W JPT/SWS CET CON Junior Power Timer 282193-1 CONN JR PWR TIMER 4POS 5MM BLACK Junior Power Timer 282192-1 CONN RCPT HSG 3POS 5.00MM Junior Timer 1-827578-1 JUNIOR TIMER CONNECTOR-HSG Junior Timer 827551-3
      Male Pin CONN TAB 17-20AWG CRIMP TIN 2-962842-1
      Female Socket CONN SOCKET large AWG CRIMP SILVER 929937-1 CONN SOCKET 13-17AWG CRIMP SILVER 929939-6 CONN SOCKET 17-20AWG CRIMP GOLD 2-929941-1
      Wire Seal SINGLE WIRE SEAL FOR J.P.T.CON 828904-2
      Boot BOOT 4 POSN HSG 493581-1 COVER CAP, 3 WAY 880811-2 COVER CAP , 2 WAY 880810-1
