Groaning noise after TB change
  • Aleman
    • Mar 2012
    • 1607
    OK gang - I finally got a video w/ sound. Going for a drive yesterday, heard at cold startup, the noise went away once up to operating temp. I've confirmed it isn't the PS pump by removing the belt. I don't notice any performance problems on the drive.
    Ever heard this noise before?
    Thanks!
    R135 /// 1990 Alpinweiß II 325is
    └┼┼┘ /// 1993 Black/Black Convertible (sold)
    ..24
    • digger
      • Nov 2005
      • 6181
      Part of that sound isnt too dissimilar to the sound you get from an overly tight belt tension. what brand parts?
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5597
        just take the other two belts off at this point
        sounds like one is way too tight
        • Aleman
          • Mar 2012
          • 1607
          Yup - I was thinking of trying that next... Stay tuned
          ..24
          • Aleman
            • Mar 2012
            • 1607
            Removed the Alternator, AC and power steering belts and briefly ran the engine. That groaning noise is still there, so maybe the issue is related to the timing belt. At this point, I'm probably just going to take it to my preferred indy shop to have them look at it.
            I've done my timing belt a couple times over the years, and the only thing I did different from usual is I replaced the lower TB cover gasket and the front crankshaft seals.
            Engine still doesn't sound happy with the drive belts removed:
            ..24
            • Aleman
              • Mar 2012
              • 1607
              Problem fixed by indy shop. It was the timing belt being too tight. There must be some trick to getting that tension correct, because last time I did the TB, the tensioner whined like a supercharger. This time I got mysterious groaning from the engine bay. The Bentley manual is leaving something out, because I always follow the guide to a 'T'.
              ..24
