Groaning noise after TB change
  • Aleman
    • Mar 2012
    • 1611
    Hey E30 hive mind -
    Have you ever experienced a loud groaning noise coming from your running M20 engine following a timing belt change?
    The noise was not there before the TB change, and it starts immediately when the engine starts.
    It keeps making the noise even after reaching operating temp.
    I suspect a faulty (new) belt tensioner, but I can't get my mechanic's stethoscope in there to confirm it. I did confirm it's not the alternator.
    Any way I could confirm the tensioner w/o taking everything apart and basically re-doing the TB job? I may not have found the right angle to get the stethoscope in there...
    TIA
    R135 /// 1990 Alpinweiß II 325is
    └┼┼┘ /// 1993 Black/Black Convertible (sold)
    ..24
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5616
    post a vid
    maybe PS fluid is low
    har har har
    • Aleman
      • Mar 2012
      • 1611
      Low PS fluid groan would be a good description of how it sounds. None has leaked that I'm aware of, but I'll double check anyway - good suggestion. I have to wait till the Philly weather moves out of frozen tundra Hoth mode before heading back out to the garage to make a vid.
      ..24
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5616
        I think the reservoir has an integrated filter as well. Maybe a combination of freezing temps, slightly dirty filter and slightly low fluid is making that pump choke a bit
        • uturn
          • Dec 2010
          • 1009
          Just remove the power steering belt.
          • roguetoaster
            Biggus Tippus
            • 7830
            Originally posted by uturn
            Just remove the timing belt.
            That'll teach that engine to make weird noises.
            • Aleman
              • Mar 2012
              • 1611
              LOL! Why didn't BMW just use a timing chain on the M20 - like every other engine they've made?
              I'll get to the bottom of it one way or another. I tend to assume to worst - like maybe an oil passage is clogged, and the noise is from my crankshaft bearings disintegrating. I'll point my stethoscope at the PS pump to rule it out as the source. Thanks for the ideas - I'll update the thread when I figure it out.
              ..24
              • digger
                • Nov 2005
                • 6212
                what brand belt, brand idler/tensioner did you use?
                how did you tension it?
                • MrBurgundy
                  R3V Degenerate
                  • Mar 2012
                  • 5616
                  Honestly, at this point- just m10 swap it
                  • McGyver
                    • 4636
                    is it like, a sexy groan?
                    • roguetoaster
                      Biggus Tippus
                      • 7830
                      We're all familiar with the noises that your mom makes....
                      • McGyver
                        • 4636
                        Glad to know someone's taking care of her, but i'll never call you dad!
                        • Dagamus(NM)
                          • 621
                          Regardless, isolating the sound to an accessory or something under the timing cover should help make the decision to pull it all back apart or not.
                          Gun control means using both hands
                          Sex, Drugs, Rock 'n roll. Pick two.
                          • Aleman
                            • Mar 2012
                            • 1611
                            Hey Digger, I followed the Bentley book procedure, like I have the previous 2 times I did the TB:
                            With the belt correctly positioned on the sprockets, slowly loosen the camshaft belt tensioner pulley upper retaining bolt so that the belt is tensioned .
                            Using a socket wrench on the center crankshaft bolt, slowly rotate the engine clockwise through two complete revolutions (720°) until the timing marks are aligned again.
                            CAUTION -
                            If either the crankshaft or the camshaft are not perfectly aligned, it is necessary to release tension on the camshaft drive belt, carefully peel the belt from the camshaft drive gear, and repeat the above steps. It is permissible to rotate the camshaft drive gear by hand by one or two teeth in either direction to ensure proper alignment.
                            Once the alignment of crankshaft and camshaft timing marks are correct, torque first the upper and then the lower tensioner mounting bolts to 22 ± 2 Nm (16 ± 1 ft. lb.).
                            ..24
                            • digger
                              • Nov 2005
                              • 6212
                              CAUTION -
                              it is unlikely to be over tensioned then, which would sound like a whine not a groan
