Speeduino Issue....
  • ADEN
    • 620
    Speeduino Issue....
    Finished my Speeduino project :
    Stock ignition but using external IGN module Bosch 123 (No IGBT where i live)
    Stock Batch injection using m60 injectors.
    External Toyota MAP (No internal MAP where i live).
    Many hours spent tuning to get the car running well, Smoother than stock idle, Engine revs to 6k happily.
    My only problem that i cant get pops and crackles to happen, I tried many time retarding the base of my Spark table and also add fuel to base ve table with no luck i also remove silencer+muffler and running straight pipes played with trigger angle -84/50/276 not a single pop.I am frustrated.
    Any help..
  • Jaxx_
    • Dec 2009
    • 1880
    Make sure you have fuel on decel (no overrun fuel cut on), timing should probably be in the low teens at the bottom of the map. Near stoich or lean of stoich is best in my experience, as flame speed is relatively slow when the mix is lean.
    • ADEN
      • 620
      It is -10 over run fuel cut off ....Nothing
      I am running on the rich side.
      • Jaxx_
        • Dec 2009
        • 1880
        What's the max timing the distributor can do? Aren't they limited to a certain amount of retarded timing? I would try something in the 10s BTDC not ADC.
        If still nothing try targeting 15.0:1 gasoline AFR in that area of the map. A long few WOT pulls before decel won't hurt either :)
          • 34844
          Sounds like it's tuned perfectly to me.
          • ADEN
            • 620
            You are right, Maybe distributor limitation is the cause of this.
            Please if someone succeeded to get the pops with the stock distributor please let me know i will be appreciated.
            • ADEN
              • 620
              Please give me your thoughts, I know i should have attached my tune file but currently i'm out of town.
              • Jaxx_
                • Dec 2009
                • 1880
                You really don't need crazy retarded timing. I was getting pops at like 20 deg of timing BTDC on my M10. As I said, the flame speed is so slow with a leanish and low density fuel mix (high vacuum) that the combustion cycle will likely not be finished before the exhaust valve opens. Have the car tuned normally(let's say approx stoich on decel), disable any fuel cut, and put timing to flat 10 degrees where the decel cells are. I will be very surprised if you don't have any pops and bangs.
                • ADEN
                  • 620
                  Are you running wasted spark?
                  • Jaxx_
                    • Dec 2009
                    • 1880
                    Yes. Great point. :)
                    • ADEN
                      • 620
                      Thank you i will look for wasted spark coils with internal igniters since no IGBT source found.
                      • Austrianvespaguy
                        • Aug 2018
                        • 88
                        Use this one, it's from late 2000s GM cars with the 3.9L V6. Has built in ignitors so only need to feed it with +12v, ground, and your three logic level spark outputs!
                        Here on Amazon:
                        https://www.amazon.com/ACDelco-D599A.../dp/B0010GEBSA
                        Or just grab one for Autozone, 2008 Monte Carlo is an example that should get you to it. Use plug wires from the same.
                        • ADEN
                          • 620
                          Here on Amazon:
                          Thanks alot man that's a good option.
                          • Austrianvespaguy
                            • Aug 2018
                            • 88
                            I run it, you can even (barely) see it the bottom LH corner of my avatar pick, and it works wonderfully! Even measured the spark energy at work on the scope and it makes a solid ~125mJ when fully saturated at 6ms dwell. Don't dwell it quite that much though to keep it cooler; I'd suggest 4.0-5.0ms as the sweet spot. Less than 3.5ms and energy starts to drop below 50mJ though, so keep it above that.
                            • ADEN
                              • 620
