Microsquirt M20 Stroker w/ITBs (Fuel, Spark, No Start)
  • oprahhwinfreyy
    • Apr 2015
    • 170
    At my witts end currently on getting my engine build finally running.
    Some preliminary info about my situation:
    • M20B27 Block, Overbored
    • High Compression CP Pistons
    • 885 Head Swap
    • M50 Injectors
    • Racehead ITBs
    • Stock Exhaust Manifold
    • Stock rotor and distributor + stock single coil
    Im using the Tunerstudio with the V3 Microsquirt + Microsquirt harness tied into the C101 and the C191.
    The crank pos sensor wiring has a 10K resister in parallel.
    Im getting spark, fuel pump prime, im getting an uninterrupted tach signal. I can hear the pump relay kick on and the injectors clicking as im cranking, but no start. Not even a gurgle of combustion. I pulled the plugs after cranking, and it doesnt seem like theres much fuel on them if any. Fuel rail gets fuel and pressurizes as far as I can tell.
    So I'm thinking its my tune. Ive never used tunerstudio before and never used an aftermarket ecu before. It seems like its something simple that I'm missing that I just don't know about.
    Im trying to attach my tune and my composite log to this post, but its saying I cant upload .msq or .csv file types. Any help is appreciated.
    Edit:
    Here are download links of the files from my google drive:
    Tune:Log:
    Last edited by oprahhwinfreyy; 07-31-2024, 01:54 PM. Reason: Added Links for file downloads.
  • It's Soda Not Pop
    • Jan 2022
    • 877
    jakeb might could help. He doesn't always get on this forum. But he does have a website call Classicdaily.com. But I'm also sure that there are plenty of people on here that can help. I've recently went standalone and I'm also learning as well.
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
