Title catches most of the question but here it is.
Can i use stock intake system without the afm in Alpha-N mode in MS to run a never run 3.1L stroker? My thought is to use the variable TPS, wideband O2 and IAT sensor to see if i can get this motor broken in before i go back to the ITB setup. Thoughts? Im trying to spitball ideas as to how i can get this motor to run as ive tried stock ecu and 19# injectors and it wont run for longer than 10 seconds, but i wouldnt even call it running…i posted another question on the m20 section but had this idea and is more appropriate here i think. Thanks guys
