Ideal Megasquirt Setup
  • SwiftE30
    • Jun 2010
    • 998
    What would be the ideal megasquirt system to run with an 89 325i with an s52 swap and a garret gt35 or gt40 turbo setup?
    Im leaning towards a Megasquirt-II with a V3 board with 34lb or 39lb injectors.
    If your running a setup you really like, let me know what it is. Any suggestions would be awesome. THanks
    1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
    • 34844
    MS2 is almost a downgrade from the stock computer - batch fire, although you can do COP, and it's much easier to tune and it can do other stuff the stock computer can't (boost control, launch control, etc).
    I think for the price difference MS3 is the way to go. $365 for the V3.0 kit, add $90 for the MS3x sequential board and you've got a pretty complete system for not that much money.
    • e30polak
      • 6136
      1. Unless you or your tuner have tuned a VANOS motor before, don't waste your time and money on MS. Spend the cash and get a tried and true tune from someone like TRM. Drive-ability will be much better across the board, and will allow you to take advantage of VANOS.
      2. That injector size will be too small for a gt35r or gt40.
      Do some research on bimmerforums' Forced Induction section, there's all you need to know there. ;)
      INSTAGRAM: @UNDR8D_EMPIRE
        • 34844
        MS3 can easily control VANOS.. but whatever.
        • dave.a.cote
          • Jul 2009
          • 246
          I just got my 11:1 2.9L M50 running on MS3 with MS3X and couldn't be happier. It is fully sequential COP plus MS has a bunch of features you would have trouble with on a stock ecu - I plan on adding launch control soon.
          1988 325 auto-x car
          1989 325ix winter car
          1991 525i summer car
          • matt
            • 3732
            Don't bother with anything less than the latest and greatest megasquirt.
            Or get a proper tune from us. :)
            • e30polak
              • 6136
              Never said it couldn't, but very few tuners are able to tune the VANOS motor as smoothly as the stock ecu allows. Things get even worse under boost.
              This.
              After driving multiple turbo cars, I've never seen such smooth drive-ability as those tuned by TRM.
                • 34844
                dude, single vanos motors are ON-OFF-ON, based on RPM/Load. it's not rocket science.
                boost has nothing to do with it. You basically want to set the cam timing for the highest torque at that load site. at lower loads you might compromise to make it a bit smoother.
                and i've seen plenty of stock ECU motors with huge torque dips at the vanos switchover point. So just because it's a stock tuned ECU doesn't mean it's smooth. Whoever is tuning it still has to know what they are doing. the hardware is irrelevant.
                infinitely variable double vanos is a little more difficult, but certainly not impossible. and that's not what we are talking about, anyway.
                • SwiftE30
                  • Jun 2010
                  • 998
                  http://forums.bimmerforums.com/forum...play.php?f=150
                  You gotta be able to start somewhere. Thats the whole point of restoring a car in my opinion. I would rather learn how to do it rather than letting someone else do it.
                  • SwiftE30
                    • Jun 2010
                    • 998
                    http://www.r3vlimited.com/board/showthread.php?t=181166
                    I like this. Not that much money and seems like an awesome setup.I'll look into that combo more. THanks. What size injectors are you using?
                    • mikeday
                      • Apr 2008
                      • 477
                      Im selling my megasquirt and pnp adapter board...
                      You should buy it ;)
                      • dave.a.cote
                        • Jul 2009
                        • 246
                        I am using 24lb injectors with a 3.0 bar FPR. I am also running an Innovate LC-1 and to get AFR's in the 12.5 range at 6k rpm, I am seeing about 80% duty cycle and an outside temperature near freezing.
                        I tried to build it on a budget. I am using dual intake cams, ebay headers with dual 2" exhaust, m20 single mass flywheel. I am hoping to be around 210 hp at the wheels.
                        1988 325 auto-x car
                          • 34844
                          I'm using 42#, but it doesn't really matter that much with standalone. Although you don't want to go too big because idle pulsewidths will be too small and it will be harder to tune at low loads, 24# are probably plenty. 42# have been fine for my engine though, I got them because they were basically brand new and a friend gave me a good deal.
                          • dave.a.cote
                            • Jul 2009
                            • 246
                            nando, what is your engine configuration?
                            1988 325 auto-x car
                              • 34844
                              M20B28
                              the injectors are probably about double what I "need". Max duty cycle is somewhere around 40-45%. But having large injectors means I can more easily control the PW at high loads, so it's a bit of a trade off.
