I just want an iPad port. :)
Miller WAR Machine 24v Rendition
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpic -
215 for a tuned S52 cammed M52
I would think you would be at least at 230.
Does it have headers or anything else done?
Edit Saw it has:
24Lb injectors
3.5 euro MAF
S52 cams
obd1 manifold:nice:Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.Comment
No one said the power was from the MAF, it was actually mentioned the gains were from the tune, not the presence of the MAF. But, like the 19# injector upgrade for the M20, its just something people do and want software for...Last edited by brody; 08-01-2011, 02:15 PM.Comment
So it is like "don't ask don't tell" philosophy
As long as people buy parts that won't make them any more power you will make moneyComment
I mentioned that the gains were not from the MAF, but from the tuning of the engine. which, regardless of what MAF would have been used it is an engine that doesn't have stock OBDI management.
I'm not here to argue with people who want to use a 540 or euro MAF. They want a solution to use it, so we, like everyone else who can, provides them with one. People don't care if it makes a difference. Look how many STOCK m20 guys run 19# injectors. People just WANT to do things.Comment
Alot of smart asses ITT. 230whp is s52 territory and even matt from TRM will freely admit that a 3.5"HFM doesn't give you gains without at least shrick cams, it's a known fact.
'89 Alpine S52 with goodiesComment
I see Dan almost every time he's in LA tuning. He recently re-tuned one of our Castro built turbo cars.
Please show me some M3 cammed m52s with the same mods, and any off the shelf tune making 230whp. :roll:
That's a healthy s50/s52 with the same mods and a tune. 215whp is very healthy for the set-up they're running. :grin:
It's a popular mod that has been beat to death on bimmerforums. Dan and Brody are simply catering to the people that own those MAFs already, The 3" MAF is just as efficient, but almost every big 24v tuner out there has a tune for the larger MAF.
There's no market for Dan and Brody to sell MAFs other than they're own, they're not trying to make extra money off of anyone. :roll:Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
I cant wait to see what I can make with a war chip with my setup. pnp, schricks, 3.5hfm, headers, cai, 24# injectors, lightweight flywheel, etc.I don't always wreck cars, but when I do I wreck them into trees.
91' 318is S50 swap - The Black WidowComment
I was asking originally because I wanted to know if it would be like some of the chips on the market that can delete the EWS. Or in the WAR chips case have the ability to delete it with a dialogue box or however you have your program set up to have it disabled.
I have no intentions of running OBDII with my swap but I have an easier time sourcing EWS DME's locally than not.BMWCCA # 482566
Check out my Leather Shift Boots for Sale HereOriginally posted by nandoalso, I can't think of any BMW special tools you need to do a headgasket on an M20. you could nearly do it with the trunk tool kit, some bubble gum, and string.
Check out my other work with my GF Here Great gifts for your Wife or GFComment
We are working on proper EWS delete software right now. Dan has been away a lot over the past few weeks so we haven't been working on it. When he gets back this coming week, progress will resume.I was asking originally because I wanted to know if it would be like some of the chips on the market that can delete the EWS. Or in the WAR chips case have the ability to delete it with a dialogue box or however you have your program set up to have it disabled.
I have no intentions of running OBDII with my swap but I have an easier time sourcing EWS DME's locally than not.Comment
BMWCCA # 482566
brody I've got a question. Currently running an OBD1 S52 with S50 stock chip, 3" MAF, m50 manifold. I get a check engine light at redline and a "air flow meter, signal implausible" or "signal out of range" or something similar code. Code goes off as soon as revs drop below 6500 or so, it basically flashes like a shift light. Have tried other MAFs, same thing. Anyways, I'm sure I'm leaving power on the table without a custom tune, but my question is, does it sound like my setup is past the limits of the 3" MAF or if I got a war chip from you guys would the computer be able to deal with the MAF signal? I suppose adding a resistor to the signal wire would be a possibility, thus scaling the voltage the computer sees down, and tune appropriately, would you recommend against that (assuming the WAR chip can't handle it unresisted).
Anyways...hopefully question was clear enough. The car runs fine now but I do want a proper tune, and when I get one it'll be from you guys, I just wanna know what hardware I need to gather first.
Thanks
-SamComment
thats interesting i have the same problem. the check engine light comes on for like a split second at redline. then as soon as i let off to shift the light goes off again. and it was a troublecode for maf sensor but for what specifically i cant remember. i also have an obd1 s52 but im running an off the shelf trm chip.Comment
