Miller WAR Machine 24v Rendition
  • BimmerTim
    • Oct 2007
    • 613
    #91
    I have recently finished up my E30 S50 Turbo build and I'm running the Miller Performance 24v Turbo Tuning Package. It's fantastic. Everything works awesome.
    I can't say enough good things about Brody and Miller. There were a few hiccups along the way, but Brody and the Miller crew were second to none when it came to resolving the issues.
    I would 110% recommend Miller product to anyone.
    Thank you so much for putting up with me Brody. haha
    1988 Bronzitbeige Metallic 325e 2-door S50 turbo (OO=( )=OO)
    2008 VW Rabbit
    1991 Audi 200 20vtq Wagon
    • e30polak
      • 6136
      #92
      Give Dan some credit as well, he's the one that did the actual tuning. :p
      INSTAGRAM: @UNDR8D_EMPIRE
      • BimmerTim
        • Oct 2007
        • 613
        #93
        That's why I said crew as well. I'm not local, so I have never met any of them, and I only spoke and emailed with Brody.
        Either way, brilliant.
        2008 VW Rabbit
        • e30polak
          • 6136
          #94
          I know, I know, just being a smart ass.
          • tttoon
            • 275
            #95
            dumb question over here, but before I blow shit up, can you change tunes with the TCM with the motor running?
            • brody
              • Jul 2009
              • 334
              #96
              Yes. Once it a while it may stumble but it is totally safe to do.
              • Bearmw
                • 1323
                #97
                Brody can you clarify how WAR works in relation to the stock DME's ability to adapt and learn and tending to revert back to the set stock AFR of about 14:1. If I adjust the fuel and timing maps to where I want them based on my specific injectors and fuel pressure wont the stock DME then begin to correct my adjustment back to the factory settings?
                Anyone?
                • brody
                  • Jul 2009
                  • 334
                  #98
                  Anyone?
                  Why wouldn't you want it to be at Stoich for Part throttle? The ECU's do not "correct" under WOT.
                  If you really want to run on the rich or lean side all the time without having the ECU correct (during part throttle and idle conditions only anyway) just turn the O2 sensor off in the software.
                  • Bearmw
                    • 1323
                    #99
                    Thanks for the reply. I think I'm starting to understand how your WAR system works.
                    • Butler
                      • Nov 2009
                      • 1613
                      #100
                      Updates?
                      -Nick
                      Originally posted by 87e30
                      First of all: calm the fuck down; second of all; cool story bro.
                      • Bimmerman325i
                        • 6854
                        #101
                        Brody, question for you on vanos trigger points. I'm looking at buying the WAR chip to tune my US S50 (ITBs, wild cams, full exhaust, injectors, etc) and am wondering what trigger points are available. Since my car is running wild cams I am thinking that I'll need to play with vanos well outside the normal realm of trigger points.
                        Additionally, how much higher can the redline be bumped from the 7k normal point? My engine should be able to go 7600-7800 once it's fully built, and hopefully make a good deal of power that high.
                        I'd probably end up doing a remote tune from you guys rather than tune it myself, but I'm curious what options there are for a wild NA build vs a turbo/stockish engine.
                        2017 Chevrolet SS, 6MT
                        95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                        98 M3/4/5 (stock)
                        • trackjunkie21
                          • Jan 2010
                          • 3962
                          #102
                          So there is no way I can use this on a Non Vanos engine? Oh well.
                          Originally posted by Wh33lhop
                          VANOS: sometimes you just need to go full retard.
                          • Bimmerman325i
                            • 6854
                            #103
                            What? You definitely can, it's just a different application and you don't have the vanos maps.
                            98 M3/4/5 (stock)
                            • trackjunkie21
                              • Jan 2010
                              • 3962
                              #104
                              My friend tried to get a chip for his non vanos turbo and was told there was nothing available.
                              • Bimmerman325i
                                • 6854
                                #105
                                How recently?
                                98 M3/4/5 (stock)
