M52B28 megasquirt
  • nassso
    • Nov 2011
    • 6
    M52B28 megasquirt
    Hello,
    I have M52B28 with M50 manifold, induction kit. Right now i am converting to Megasquirt. Is there anyone who have similar setup to send me his map?
  • howelll
    • Sep 2009
    • 198
    which megasquirt are you going to use? Here is one that can get you started
    I'm running ms3+3x with s52 cams, with tuner studio the ve analyze will get your ve map pretty easy. The timing map is where its hard to get just right without a dyno, I haven't found a m52b28 timing map pulled directly from the dme.
    • 328ijunkie
      • May 2007
      • 3961
      Why use megasquirt when you can easily run the factory ECU?
      Check Us out on Facebook
      Full Product Line Tuning
        • 34844
        because if you want to tune it (for boost) yourself - well, you can't.
        • howelll
          • Sep 2009
          • 198
          Not easily, you have to swap over all the ews stuff or convert to obd1. He may also be going with forced induction.
          Sent from my DROID BIONIC using Tapatalk
          • 328ijunkie
            • May 2007
            • 3961
            You can easily get EWS deleted from the ECU, i run all my customer swaps OBD2 that i can.
            • goarmy
              • Nov 2011
              • 622
              ecu
              how? do you sell chips? is so for what ecu?
              • 328ijunkie
                • May 2007
                • 3961
                I sell OBD1 chips and can flash OBD2 ECUs with whatever mods you want as well as deleting EWS/SAP/etc...
                  • 34844
                  not the same thing as dyno tuning something yourself. remote tuning works well N/A, but it's a hell of a lot more difficult (and slower) than dyno tuning something live.
                  • samiam3356
                    • Jul 2009
                    • 1901
                    TRM here in Atlanta. Matt on the forum can help you out. Screen name = Matt
                    Whodwho makes plug-n-play kits. Might try pm'ing him if your dead set on MS.
                    Originally posted by Roysneon
                    $5 shipped?
                    Originally posted by MarkD
                    You are a strange dude, I'n not answering any more posts from you.
                    • 328ijunkie
                      • May 2007
                      • 3961
                      True thats why theres this ;)
                      • 328ijunkie
                        • May 2007
                        • 3961
                        I no longer use TRM products.... :/
                        • samiam3356
                          • Jul 2009
                          • 1901
                          nevermind, saw the link
                          $5 shipped?
                            • 34844
                            that doesn't allow live tuning. it's still remote - it's better than an off the shelf chip, but definitely not the same as a full standalone setup tuned right in front of your face, live, with dyno feedback.
                            • nassso
                              • Nov 2011
                              • 6
                              The car have S52 Cams and the original Ecu is terrible for remaping. There is adaptations and the response and power under 4000rpm is terrible. I want megasquirt because i don't want to have any adaptations, i want AFR that i like. The car will have megasquirt 2 v3
