M52B28 megasquirt
  • nassso
    • Nov 2011
    • 6
    The other problem of the stock DME is that it doesn't support live mapping so it's impossible to tune it well.
    • nassso
      • Nov 2011
      • 6
      Some updates. The car is already with MS2. Starts and works perfect. The only problem i have is the Vanos conrtrol. I am using PA0 output for control. The problem is that when the vanos is turned on under 3500 rpm there is very loud rattle from the intaker manifold. Also i am not sure if this ouput ports support off-on-off. I think they only support off-on or on-off. Any ideas?
      • E34DIYer
        • Mar 2014
        • 197
        Any updates on your MS-powered M52?
        • Northern
          • 5164
          It's almost funny how much more OBD2 ECU support there is now than there was in 2011.
          Originally posted by priapism
          Originally posted by shameson
          • 328ijunkie
            • May 2007
            • 3961
            yup
            Check Us out on Facebook
            Full Product Line Tuning
