Miller WAR Chip software load axis
  • Mako18
    • Jul 2006
    • 688
    Warchip have any hit tracing function? What are our logging options?
    My ostrich 2.0 and tunerprort combo has real time hit tracing but still trying to figure out a data logger.
      • 34847
      Originally posted by ilateapex
      How are you guys doing the timing tuning? Worried about knock?
      Michael
      use a dyno..
      • fporro
        • 1860
        Thanks for info Brody, finally got RD headers so ready to fine tune it.
        Do you have any tunes for m20's with itb's?
        Tryed all 3 housings, medium one seems to work best so far.
        • Tchao
          • Apr 2007
          • 223
          I think some of you guys are confusing this with a standard SpeedDesity type tuning where the cells directly mean fuel amount.
          With the MAF, it's super simple as the values means AFR so to speak. The number itself isn't the same but the values mean the same. Find out what values brings you to...say 13:1 and set that value, say #130 across the board for part throttle and do small adjustments from there, again in a general area, not cell per cell. Say light throttle (ie cruising) you probably don't want 13:1 (130) so lean it a bit out, either that's a higher or lower value.
          Correct me if I'm wrong. But MAF tuning is super easy if the kit is already calibrated.
          • MonkeyMan
            • Jul 2011
            • 426
            subscribed! I'll try to get a screen shot of my p/t timing and p/t fuel maps, but I think I got them both nailed.. I had my car dyno tuned, but the most we could do in approx 2 hours of work was WOT settings..
            I used those numbers as a good baseline and tuned the p/t settings to a smooth curve that transitioned from idle and no load to almost full throttle with heavy load..
            I'm pretty familiar with the software now and will continue to make tweeks as necessary..
            Make the bastard chase you.
            • rvaughnp
              • 136
              Can anyone lead me to info on getting the graph software? And then how to transfer the WAR info to the program?
              thanks.
              • JCarp90
                • Feb 2011
                • 1759
                thanks.
                www.millerperformancecars.com
                • rvaughnp
                  • 136
                  As much as i appreciate the link to Millers website... they don't have a link to any software or any info on where to get it.
