My LC-1 Installation Guide
  • imwhyteyo
    • 1165
    #31
    I have everything else connected proper.. im pretty sure. The purple and green wire, is the power to the fuel pump.. it turns on momentarily when switched on. So ive spliced I to that.. but im stuck as to knowing where to connect the splice to.
    • bmwman91
      • Oct 2004
      • 3134
      #32
      I am not familiar with the wiring on the 325iX, so you'll need to find wiring diagrams and see what's what.
      I have also updated the original post to mention that I no longer recommend the Innovate LC-x products.
      Transaction Feedback: LINK
        • 34839
        #33
        you could use a PWM module off a junkyard E46 and do the same thing. pretty sure you could score one for $25 or less.
        it's got power, grounds, and the PWM signal. MS2/3 has enough PWM outputs to control that no problem.
        • jrsaucke
          • Jun 2013
          • 125
          #34
          I'm struggling with the install of my LC-2. There is only a single ground for the LC-2 so the wiring doesn't really match what is here.
          I cannibalized a stock O2 sensor harness and spliced the LC-2 into the other half of the original O2 sensor. I popped open the relay as shown in the first post and shorted it. Everything seems to work fine. The engine runs and settles in at stoich after it gets up to temperature, but I am getting a stomp code and hesitation (I think the hesitation is a different issue).
          1264: O2 sensor heater
          Did I wire this up incorrectly?
          Edit: Still running motronic at the moment
          • bmwman91
            • Oct 2004
            • 3134
            #35
            Maybe you accidentally damaged the coil in the relay? I THINK that the O2 heater code is given when it thinks that the relay is not present.
            • jrsaucke
              • Jun 2013
              • 125
              #36
              Is there any way to tell if I damaged it without cannibalizing another relay? I do have a spare(s?).
              Maybe the solder connection inside is bad. I seem to remember it struggling to take hold on one of the surfaces when I did it, but I thought it eventually took.
              • jrsaucke
                • Jun 2013
                • 125
                #37
                Hmmm is anyone using an LC-2 with motronic without a check engine light?
                • fporro
                  • 1859
                  #38
                  thanks for great write up !
                  cheers,
                  Frank
                  • ak-
                    • 12422
                    #39
                    Try jumping it with external wiring on the forks instead on your spare relay and see if the CEL goes away. A code is a code and it's directly pointing to the relay and/or wiring so give it a shot!
                    1991 325iS turbo
                    • Need4Speed1299
                      • Oct 2007
                      • 119
                      #40
                      Is the same procedure required for an mtx-l?
                      • Chris Spiegl
                        • Aug 2016
                        • 155
                        #41
                        I am! I have the signal going through the o2 sensor harness. The power comes from somewhere near the cig lighter.
                        I am about to switch over to a megasquirt unit. Any tips on where I should ground it? Is the shocktower okay for megasquirt?
                        1987 325is 2.8L Stroker Turbo "Little Pickle aka The Green Turbo Sled"
                        • jrsaucke
                          • Jun 2013
                          • 125
                          #42
                          Coming back to this. Still bugging me as I'm about to get the car on the road finally. I checked my relay and there is zero resistance between pins 87 and 30.
                          Considering putting a normal O2 sensor back in for now...
