Megasquirt M62 e30. Would it work?
  • kevinbednarek
    • May 2012
    • 35
    So, after messing with all of this wiring for ages trying to do this swap, I figured I'd go the MS route. It would save money later in tunes when the turbos are added later. However, would this affect the EWS system? I can't say I know a whole lot about MS, so would you be able to program it in such a way for an "EWS delete" sort of thing? My fear is not being able to operate the starter solenoid since it needs a coded signal from the EWS module after getting a confirmation of sorts from the original DME. Has anyone done a similar setup on an M62? And would anyone know where I should start in terms of reading material, places to get the components, people to talk to, etc.?
  • bmpde30
    • 10
    Miller now has a m60/m63 war chip
    • nrubenstein
      • 3148
      Wow.
      Uh.
      What makes you think that the starter needs a coded signal? The only thing that EWS does is interrupt a power wire and tell the DME that it is ok to run the engine.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • Sharino
        • Jun 2005
        • 186
        If your running MS you will not have EWS as you will not be running a BMW ecu.
        www.eurowinnipeg.com
        www.E30S38.com
        E30 Mtec2-S38 | V10 TDI treg | E34 M5 | E39 M5 | Corrado turbo VR6
          • 34844
          it can do everything except the E-throttle, including Vanos control.
          you definitely want MS3 for this so you can run sequential fuel and spark.
          • scott66
            • Feb 2012
            • 6
            what he said ^^
