VEMS install
  • DTMbimmer07
    • 1485
    VEMS install
    About how long do you guys think it would take to install a VEMS if you have their generic wiring harness they sell? I'm looking into getting a local shop by me in orlando to put mine in for me and just wanted to get an idea of about how long and much money it will probably take.
  • DTMbimmer07
    • 1485
    no one have any input?
    • wazzu70
      • Jan 2005
      • 1143
      With the VEMS harness it shouldn't take that long to fit it to your car. Its still going to take a couple hours though. Dont have any gnats nuts estimates though.
      Most people make their own, so I have no idea how long it would take a shop to do it.
      -Nick
      M42 on VEMS
      • DTMbimmer07
        • 1485
        I had a shop quote me 8-10($800-$1000) hours to install it. I thought that was a little long. What do you guys think.
        • wazzu70
          • Jan 2005
          • 1143
          I was going to say to plan a whole day. They probably are overestimating to make sure the job does not cost more than you are prepared to pay.
          -Nick
          M42 on VEMS
          • DTMbimmer07
            • 1485
            Does anyone else have some experience with shops installing VEMS?
              • 34844
              seems cheap to me, honestly. how many VEMS systems have they installed?
              why not make it PnP?
              • DTMbimmer07
                • 1485
                They have never done it before. But they have installed a Pectal ecu in their e46 M3 race car.
                Really? I thought it was a bit on the expensive side since i have the premade wiring harness from VEMS. Is there really that much more work still involved?
                  • 34844
                  Its a generic harness you said. They are going to have to learn the e30 wiring at the same time they are hooking up an unfamiliar system.
                  A pnp adapter would be significantly cheaper.
                  • wazzu70
                    • Jan 2005
                    • 1143
                    What Chris said. You just have the econoseal connectors and wires connected. They still need to figure where to route all the wires! Thats the tough part.
                    A PNP adapter would be so much faster and easier.
                    I can help you figure what VEMS pin goes to the motronic harness.
                    For my install I just cut the Motronic connector off and put those wires into the Econoseal plug. I then ran lines to everything else the factory Motronic did not come with.
                    -Nick
                    M42 on VEMS
                    • DTMbimmer07
                      • 1485
                      Starting to think that i should do this again. Cause for $800 i can get my turbo manifold and Dp. Only thing i really need help with i think is the wiring for my bosch motorsports coil 3x2. and then for the sensors with two wires.
                      • wazzu70
                        • Jan 2005
                        • 1143
                        The coil is easy! What sensors do you not know?
                        -Nick
                        M42 on VEMS
                          • 34844
                          gunni makes a PCB based PnP adapter specifically for the M20. plug it in and go.
                          making your own is alway san option of course.
                          • wazzu70
                            • Jan 2005
                            • 1143
                            If Gunni already sells an M20 adapter....go that route!
                            -Nick
                            M42 on VEMS
                            • DTMbimmer07
                              • 1485
                              Do you guys know how much he charges for them? I still kind of want to use the wiring harness i have already though.
