CEL after chip installation
  • harold30
    • Jul 2011
    • 180
    Hi Guys,
    It's my first time changing ecu chip. After installing the new chip I started the car for a 1 minute or 2 then after 1 hr drove the car around the city to test the car performance. I noticed I got an CEL, I did a stomp test and got a 1211 fault code which indicate a dead DME/ECU. The car starts and runs fine. Does the fault code really points to ecu problem or other things? I don't have an CEL prior to installing the chip. Please advise what to do next.
    Thanks in advance.
    -Harold
  • harold30
    • Jul 2011
    • 180
    I removed the negative cable from battery for overnight and will try it again tomorrow. If it still there I guess I have to replace the ecu. one last question, what happen if I always drive the car while having 1211 fault code?
    • Killacortes
      • 1937
      Did you install the chip correctly? I think there's a groove mark on one side that you have to match while installing it.
      r3v does not fuck around. First you get banned, then they shoot you
      • harold30
        • Jul 2011
        • 180
        yes i did put the chip correctly
        • harold30
          • Jul 2011
          • 180
          anymore thoughts?
            • 34844
            checksum error.
            what kind of chip was it?
            • bmwguy325is
              • May 2011
              • 1263
              Originally posted by nando
              checksum error.
              ^----This
              or
              Did you buy chance static shock the board when you swaped the chip? Or did u bend any of the tabs on the chip?
              sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
              The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
              • harold30
                • Jul 2011
                • 180
                checksum error.
                i bought it from e30zone.net UK
                • harold30
                  • Jul 2011
                  • 180
                  Originally posted by bmwguy325is
                  ^----This
                  or
                  i think static shock was the cause. and yes i bent the tabs on the chips by hand (that was my mistake)
                  anyway, i reverted the chip back to stock and CEL is gone.
                  • harold30
                    • Jul 2011
                    • 180
                    If the car starts and runs fine with chip installed and has 1211 fault code, does it mean checksum error? And eventually it will gone?
                    • harold30
                      • Jul 2011
                      • 180
                      bump...
                      • bernzpeed
                        • 3917
                        what kind of ecu do u have and what chip?
                        89 E30 S52
                        Transaction Feedback.
                        • harold30
                          • Jul 2011
                          • 180
                          173 ecu and chip is from e30zone.net UK
                          • harold30
                            • Jul 2011
                            • 180
                            In line to this question, what are the possibilities may happen?
                            thanks!
                              • 34844
                              a checksum error is coded into the chip, it's not going to go away.
                              if it runs fine I doubt there would be any real problems except for the constantly annoying CEL. it tells me either the guy who made the chip made an honest mistake and forgot to correct the checksums, or he didn't know what he was doing.
