E36 TPS noise - already shielded vref and signal wires
  • saturnv7890
    • Jan 2011
    • 696
    Like the title says I'm experiencing some bad noise with my E36 tps. Here's the log, it appears I only get the noise when the car is on:
    (I know the log looks bad... turns out I had a spark plug unplugged)
    I've already shielded the wires going to pins 52 and 53 on motronic for vref and signal.
    Where is a good solid ground I can use? Would a shielded wire running to a good ground help tame this signal?
    It's really annoying using MapDot, as this really sucks for some reason. When I get on the trottle the car like stops for a split second before accelerating nicely.
    Any other things I should try? I know Nando said in a thread that wires not hooked up properly will cause noise and calibration issues. I don't have any calibration issues I don't think.
    Would love any helpful input on this issue, I love how smooth the car is with tps ae, but the noise really messes up my AFR's and the car is really inconsistent at constant speeds.
    My Transaction Feedback
    My "build" thread
    BUY MY CAR!!
  • e^2
    • Dec 2010
    • 65
    Are you grounding the shield on both ends or just at the ECM?
    1984 325e
    2000 323i
    • saturnv7890
      • Jan 2011
      • 696
      Just at the ecm
      My "build" thread
      BUY MY CAR!!
        • 34844
        did you swap pins 1&2 before hooking it up to the stock E30 TPS connector?
        • saturnv7890
          • Jan 2011
          • 696
          Doesn't appear that they've been swapped, is that worth a shot then?
          My "build" thread
          BUY MY CAR!!
            • 34844
            Yes, the backwards sensor makes noise issues worse.
            • saturnv7890
              • Jan 2011
              • 696
              Okay I'll try it out and let you know how it goes!! Thanks for the reponses! I'll be back tonight with results
              My "build" thread
              BUY MY CAR!!
              • saturnv7890
                • Jan 2011
                • 696
                Oh here's a quick one, which one is pin 1? Brown/blue or brown/black?
                My "build" thread
                BUY MY CAR!!
                  • 34844
                  I think they are labeled, but they're definitely shown in the ETM by wire color and pin #.
                  • saturnv7890
                    • Jan 2011
                    • 696
                    Got it, I cut the blue wire and nothing blew up!!
                    Switched them and it helped with noise a little bit.. now tpsdot is definitely useable, but it's still a little messy. Any more ideas?
                    My "build" thread
                    BUY MY CAR!!
                    • e^2
                      • Dec 2010
                      • 65
                      Does the noise show up on any other sensor inputs?
                      1984 325e
                      2000 323i
                      • saturnv7890
                        • Jan 2011
                        • 696
                        Here is a log:
                        It appears that a lot of the signals are noisy, but that could just be the constant variations in the actual info they are reading?
                        My "build" thread
                        BUY MY CAR!!
                          • 34844
                          Your link doesn't work.
                          what does your power signal look like? it should be pretty flat at around 13.5-14v.
                          if you have noise issues elsewhere, they will show up in all your sensors. how is your MS grounded?
                          • saturnv7890
                            • Jan 2011
                            • 696
                            Try that link. The download link you have to click is hidden in this looking group of text:
                            To download file click the link below:
                            6 11 13 PULLS.msl <-- this is the one you click
                            Filesize: 2.132 MB
                            File upload date: 2013-06-13 14:33:48
                            I'm on my work computer right now so I can't take a look at the log myself :(
                            The MS was installed by the PO (jordan325ic) so I guess I'm not entirely sure how he grounded it. It was a PNP made by RS4pro3 so it might have used the factory grounds? Where would you recommend the MS be grounded?
                            My "build" thread
                            BUY MY CAR!!
                              • 34844
                              the factory grounds are fine - but you might want to make sure they are clean, tight, and the wires are in good shape.
