E85 + Naturally Aspirated M20
  • Jodecious
    • 19
    So today I fed my megasquirted N/A 2.7i m20 some corn juice just for kicks. After some tweaking of the MS, it seems to like this stuff. Anyone else running it on an N/A m20?
  • Sagaris
    • Sep 2009
    • 2243
    Interesting. I am running MS2 but have not tried that out. I would be interested in exchanging tune settings to see how you have things setup.
    • Jodecious
      • 19
      Sure I can send my tune im still figuring out this whole MS thing lol I basically took my 91 tune and richened it up about 25-30% and added ~6 degrees of timing im just going to keep messing with it on the street until I can get some dyno time in
        • 34847
        Its not going to do a lot n/a. It contains less energy than gasoline, so you use more of it. Due to cooling abilities it can act like higher octane fuel on a boosted car, but an n/a m20 isnt even knock limited typically so there is no benefit.
        • digger
          • Nov 2005
          • 6204
          works well on higher compression engines.....fuel economy will probably suck on stockish engines
            • 34847
            Somehow i doubt a 2.7i has high enough compression - what, 11:1, 12:1 at minimum to see a gain? Wasnt ixer shooting for 13:1 with his build?
            • ZoomZoomBoom
              • Oct 2012
              • 475
              Keep in mind that it can be extremely difficult to get to MBT street tuning on corn, so dyno tuning on corn is recommended. However, like the guys above said, you probably won't see much benefit with your engine setup.
              1989 325iC Zinnoberrot
              • Jodecious
                • 19
                I have boost in the near future I dont really care about gains on the motor as it sits, I just wanted to see if I could do it and make it function properly before le turbo install. The motor isn't stock and butt dyno gains feel minimal but yes I will confirm that fuel consumption went from 14-15 MPG to 8-9 MPG
                • twolitresix
                  • Jan 2013
                  • 21
                  Sure it runs, just no point using it. A 8.8:1 M20 is not even knock limited on the poorest pump piss you can get, so raising octane will do nothing at all. I would start using it when boosted, makes sense then.
                  • ROLLingKING
                    • Apr 2011
                    • 1169
                    fuck it, he tried it
                    m20 is plenty. im simply a drifter.
                    build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
