Megasquirt options
  • cgk_iii
    • Dec 2012
    • 616
    Megasquirt options
    Which of these kits do i need to order for using MSII on my e30
  • cgk_iii
    • Dec 2012
    • 616
    Im tired of searching through so many threads to get a simple answer
    • cgk_iii
      • Dec 2012
      • 616
      Shop Classic MegaSquirt ECUs at DIYAutoTune for standalone engine management, tuning flexibility, and proven performance control.
      • Jaxx_
        • Dec 2009
        • 1880
        There isn't a simple answer... Megasquirt is totally customizable, so it's hard to say what you need without knowing what you want.
        Plug and play? doing it yourself? Do you need to drive 6 cyls or 4? 8? You have told us nothing about the setup that you want to run in your post.
        Check out the feature table here:
        I suggest MS2, but it depends on your needs.
        edit: at the bare minimum you will need the following:
        MSboard and MAP sensor
        MS2 daughter board
        Wiring harness
        You will probably need, or use your existing:
        Wideband
        Timing setup
        Ignition setup
        • Northern
          I like cupcakes & sh!tboxes
          • 5247
          If you don't want to be overly involved in ordering parts/assembly, look into the whodwho pnp setups. Tell him what you want to be able to do, and he'll make it happen.
          Originally posted by priapism
          Originally posted by shameson
            • 34839
            I would recommend a Whodwho PnP setup.
            • kamotors
              • Nov 2007
              • 7102
              ^+1 to that, Kieth is an awesome member and EXTREMELY helpful.
              7speedshop.com
              • imwhyteyo
                • 1165
                This is the route I chose.. he's been absolutely outstanding with help. Show him your actually interested In learning and not just looking for the easiest answers
