connecting generic TPS
  • digger
    • Nov 2005
    • 6182
    I have to add in a TPS and the sensor came with no connector (wires only) what is the best way to connect into the existing harness? previously ive crimped the ends with bullet or spade type connectors is this a good way? i want to try and minimise any noise in the signal
    other recommendations or tips? just solder it?
    • 34844
    Use a shielded wire. Soldering or crimping shouldn't matter.
    • digger
      • Nov 2005
      • 6182
      im not running a new wire just looking to connect into the factory harness without using the bosch 3 pin plug
        • 34844
        It will be noisy unfortunately. I've never been happy with the stock TPS wiring.
        Can you get a connector and pins for your new sensor?
        • digger
          • Nov 2005
          • 6182
          can prolly get a Bosch 3 pin male connector to plug into the harness but ive never actually made a connection with one are any special crimping tools required ?
