spool piece for intake air temp sensor (megasquirt)?
  • funcrew
    • Jun 2007
    • 1223
    Basic question, but I couldn't find anything on it: When I delete the afm for conversion to megasquirt, what do people use for a spool piece to replace the afm and mount the bung for the IAT sensor? I'd like to retain the stock air filter box as is. Summary: same inlet and outlet OD as the afm, and same length. Not going to turbo anytime soon, so need a nice solution for near stock N/A setup.
    Thanks - Tim
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • dewme5
    • Mar 2014
    • 165
    You can just leave the AFM in.
    • digger
      • Nov 2005
      • 6199
      silcone elbow/coupler?
        • 34847
        just thread it into the airbox and use a 2.5" pipe to connect the airbox to the intake boot. use an Cold Air adapter for an AFM but mount it to the airbox instead of an AFM. I use a 3"-2.5" silicone reducer.
        • ZenitramNaes
          • Jul 2012
          • 150
          Wait, you want to leave the AFM in? Is that to retain a stock look? Why not just replace it with a pipe? Kinda something similar to what I did, minus the BOV bit.
          '89 535i/5 Holset WH1E turbo
          Follow my m106 megasquirt build thread: http://forums.bimmerforums.com/forum...Squirt-content
