MS2 engine revving all the way up
  • e3irsty
    • Jan 2014
    • 134
    Driving to work I pinned it and when I pushed the clutch in to shift the engine revved up and when in gear with my foot off the gas it would accelerate. Throttle cable is fine. Butterfly flap isn't stuck or anything. Any help please.
    M20 turbo base map from whodwho
    Sent from my LG-LS980 using Tapatalk
  • whodwho
    • Jun 2008
    • 1547
    Sounds like the idle control valve maybe the issue, with the key on does the idle control valve buzz?
    Try hooking up to TS and see what the idle signal is and does it go into closed loop? Does your TPS signal go to 0%
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • e3irsty
      • Jan 2014
      • 134
      Tps was at 0. Someone else mentioned idle air. Guessing I popped it right out. I'll have to check when I get home. I'm sure that should be it. Thanks again man
      • whodwho
        • Jun 2008
        • 1547
        Could be just the elbow popped out of the throttle body
        • e3irsty
          • Jan 2014
          • 134
          Exactly what happened. Thanks
          • downforce22
            • Aug 2009
            • 3191
            That happened to me last night as night, looks like Keith diagnosed it right away.
