Well if you can't tell I'm still pretty new to megasquirt and I'm having a few issues but this one in particular has me lost. I tested it with the stock ecu and it snaps should when you turn the key on but with megasquirt on whodwho 60lb single coil base map the icv does nothing at all. Anything setting I change in the idle control tables do absolutely nothing and it it set to 2-3 wire valve with pwm.
Could there be anything else I'm missing software settings or even a hardware problem?
I also bought this ms2 used from another member but it is so build by whodwho, v1.2
Thanks,
Steve
Thanks,
Steve
