So with e30tech being down for the foreseeable future, we ended up losing a great resource in the 'Participate or Die' Megasquirt thread that was over there with a wealth of information on m20 turbo maps. As I try to tune my m20 turbo, it would be helpful to see what others have done with their m20 turbo tune and information on the map/ engine build.
So lets try to rebuild a reference again and please post the following:
Engine Specs:
Turbo Manifold:
Turbo:
Compressor Wheel:
Turbine Wheel:
Boost Level:
Injectors:
Ignition Map:
Fuel Map:
Comments:
Here is an example that I found to start us out, this is not my map but comes from a base m20b25 found at megasquirtpnp (http://www.megasquirtpnp.com/mspnp2_maps.php) for a non turbo base m20b25 running megasquirt. I'm making up the other info as an example.
EXAMPLE:
Engine Specs: M20B25 2.7i stroker
885 head on eta bottom end, all stock
Turbo Manifold: CXracing later 3-2-1 style
Turbo: Holset HX35
Compressor Wheel: 57/78mm compressor
Turbine Wheel: 60mm turbine exducer
Boost Level: 10 psi for now
Injectors: 30 lb
Ignition Map:
![](https://c1.staticflickr.com/9/8825/28487729816_1f57eb8d0e_z.jpg)
Fuel Map:
![](https://c1.staticflickr.com/9/8768/28236085240_de333e935e_b.jpg)
Comments: Boost hits hard at 3700 RPM and and pulls like a freight train til redline. OMG SO FAST!1!!
:up:
Engine Specs:
Turbo Manifold:
Turbo:
Compressor Wheel:
Turbine Wheel:
Boost Level:
Injectors:
Ignition Map:
Fuel Map:
Comments:
EXAMPLE:
Turbo: Holset HX35
Injectors: 30 lb
Ignition Map:
Fuel Map:
:up:
