Hey what's up guy listen I am having a issue with my turbo e30
Here is the set up
M20 stock
Arp head studs
Bimmer head turbo cam
Holset turbo
Whodwho megasquirt
Here is the issue every time I do a wot pull the car lean out at about 5000rpm
I try adding fuel with in that rpm did not do anything. These are the things I change
Fuel pump
Fuel filter
Injectors
Fuel pressure regulator (adjustable)
And I can't find Keith aka whodwho please help.
Here is the set up
M20 stock
Arp head studs
Holset turbo
Whodwho megasquirt
Fuel pump
Fuel filter
Injectors
