MSPNP by Whodwho and Wasted Spark
  • dzverko
    • Feb 2013
    • 92
    Hi guys,
    I bought a used MS by Whodwho and I am trying to find out if its pre-assembled for wasted spark. I tried searching online with no result and tried contacting Whodwho with no luck there either!
    My question is, where on the board should I be looking to see if the ignition drivers are installed? If not installed, do I just need to order and solder them in or do I have to do any other mods apart from the obvious ign coils and external wiring?
    On the outside the only writing I see is "M20 Turbo #30"
    I can open the MS and upload pics if need be or maybe someone has more experience with these.
    Any help appreciated!
  • nomansland92
    • 1657
    Take a picture of the board would be the easiest way to explain
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    IX being restored here
    Ix turbo build here
    • dzverko
      • Feb 2013
      • 92
      I went ahead and took some while I was waiting for a reply..
      • ak-
        • 12422
        My guess is no
        1991 325iS turbo
        • dzverko
          • Feb 2013
          • 92
          Originally posted by ak-
          My guess is no
          Yeah, I was thinking most likely it is not installed.
          My next question, is it just a matter of buying the ignition driver kits and soldering them in place or is there anything else that needs to be done?
          Sent from my VS985 4G using Tapatalk
          • Northern
            I like cupcakes & sh!tboxes
            • 5284
            your board is v1.0 while the one ak- posted is 1.4. I would really try to get info from Keith on this.
            Did you email him? I think that's really the only way to get hold of him.
            Originally posted by priapism
            Originally posted by shameson
            • dzverko
              • Feb 2013
              • 92
              I did email him with no answer. I contacted the PO as well and he told me that he wasnt sure since he never used the wasted spark option.
              I guess I'll wait a little longer and email Keith again.
              • nomansland92
                • 1657
                Flip the board over, It looks like there underneath.
                Ix turbo build here
                • dzverko
                  • Feb 2013
                  • 92
                  Here is the bottom of the board. I don't think its there either...
                  • dzverko
                    • Feb 2013
                    • 92
                    I think I figured it out! This is a pinout that Whodwho posted in another thread in regards to WS.
                    If I follow the board, the drivers are actually connected to the DB15 and Q1 is actually splits off on the front of the board, which goes to a pin for the original connector.
                    Can someone with more knowledge (as I am new to MS) please confirm?
                    • nomansland92
                      • 1657
                      I believe this is them
                      Ix turbo build here
                      • kyleconstantine
                        • Apr 2014
                        • 1380
                        Hey if those 3 transisters are bip373's(wasted spark) then the center pin will be connected to the db15 pinout you posted before. Grab multimeter and check for continuity between the center leg and ign1, ign2, ign3. To check continuity check for zero resistence(ohm) between the 2 points. Hope this helps
                        • kyleconstantine
                          • Apr 2014
                          • 1380
                          Also if those are 330 ohm resisters circled in thr first picture id bet thats it....i just cant make out the color stripes.
                          • 2002tiiguy
                            • Jul 2013
                            • 467
                            your board is set up for wasted spark, did you have fun putting those stupid tiny nuts back on when you reassembled it?
                            • dzverko
                              • Feb 2013
                              • 92
                              Yes, it does have wasted spark.
                              Those nuts where not that bad, just a little patience...
