M20 Wasted Spark MS PNP Gen2 Tune?
  • dvallis
    • Oct 2015
    • 1474
    Guys
    Getting ready to fire up Das Beast.
    Can someone share a TunerStudio Megasquirt PNP2 Gen2 M20 tune for wasted spark? I've gone through all the TunerStudio screens and think they're right, but would feel better starting from a known good tune.
    Thanks in advance
    Click image for video of cold crank
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
  • e30davie
    • Apr 2016
    • 1788
    its going to depend on how you have wired it up. There aren't many settings to change. If i recall its one drop down to change from single coil to wasted spark of A, B, C outputs. assuming you have wired it up to ABC outputs.
    I would just describe how you have wired it up, post some screen shots of your settings and let people comment. you will learn more this way....
    • dvallis
      • Oct 2015
      • 1474
      Dude, you don't want to know how much wiring we did. :devil: However, here's the setup. From Post 302 and Post 819 of Das Beast build.
      It's not the wiring I'm asking about. It's getting all the right settings of TunerStudio's 154 configuration screens. I have a known good setup with the Canyon Crusher V2 MSQ, but have not seen one for wasted spark.
      Note: switched to GM coils from MSD per ForcedFireBird suggestion
      2002 E39 M5
      • citizen_insane
        • Jan 2013
        • 216
        The only thing you need to do in TunerStudio is set the ignition setting to 'wasted spark', assign the Spark B & C to the correct outputs for your hardware configuration, and set the trigger as 'going high'. You may have to tweak the dwell settings, there's a good walk through here: https://www.diyautotune.com/support/...p373-ignition/
        Everything else is controlled by your wiring. Based on your schematics, the wiring looks correct, you just need know the names of the channels in software that correlate to pins 15 & 16 on your MS2 output.
        • ForcedFirebird
          • Feb 2007
          • 8300
          Before starting it, use the drop down menu in TunerStudio called CANBUS/TestModes. This way you can verify which coil pack is firing and wire them properly to the engine...
          john@m20guru.com
          Links:
          • dvallis
            • Oct 2015
            • 1474
            I finally found the definitive answer here.
            Moving this discussion back to Das Beast. Was really looking here for a MSQ file to work with.
            2002 E39 M5
            • dvallis
              • Oct 2015
              • 1474
              Thanks 'Bird. Will do.
              2002 E39 M5
