MegaSquirt losing crank signal
  • Malcolm206
    • Jul 2015
    • 84
    I recently installed a new 2.9L M20 with Microsquirt v3.0. I'm using the stock 60-2 toothed wheel and having an issue with the crank position sensor at higher RPMs. Once I hit around 3500 RPM, the engine acts like it's bouncing off a rev limiter/fuel cutoff. The tooth logger shows I'm completely losing the signal and counts as a loss of sink. I bridged the shunt resistor in the case, moved the CPS bracket closer to the wheel, and swapped out CPS sensors with another used one.
    Any ideas what I should try to check next?
    1988 E30 325iC
  • HerbE30
    • Nov 2015
    • 538
    Do you have a new sensor? I have heard MS is pretty picky and that they benefit from having a Bosch sensor. I have seen others use a decent brand one, but swap to a new Bosch and the issue is resolved.
    At a guess though.
    20% Accurate
    Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
    • Kershaw
      • 11822
      Try swapping in a new harmonic balancer. If that doesn't work, try a new engine harness.
      AWD > RWD
      • roads
        • Dec 2017
        • 26
        Not sure if you're still wondering about the issue but here's a related thread: https://www.r3vlimited.com/board/for...ound-4-800-rpm
        Im having the same issue right now with a whodwho megasquirt.
        • digger
          • Nov 2005
          • 6212
          would have thought that it would be more robust
