Exhaust for S38
  • Sharino
    • Jun 2005
    • 186
    Exhaust for S38
    I am making an exhaust for my S38 powered E30. It will be complete custom from the S38 headers back. I need to order some stainless materials and wanted to get some advice.
    The 2 header pipes are approx 1 7/8" think each at the joints. I would much prefer to do a single pipe of say 3" back but do you think I will regret it. Would a dual 2" be much advantage?
    Any advice on recommended sizes appreciated as well as muffler ideas.
    www.eurowinnipeg.com
    www.E30S38.com
    E30 Mtec2-S38 | V10 TDI treg | E34 M5 | E39 M5 | Corrado turbo VR6
    • 34844
    why would you regret single 3"?
    I wouldn't do anything smaller, personally. dual 2" is just going to weigh and cost more. get a merge collector for the headers to single pipe, high flow metal core cat, and a couple mufflers of your choice.
    • Sharino
      • Jun 2005
      • 186
      I just assumed you get better results with dual pipes as that was BMWs original design. I am by no means an exhaust expert. Think 3" will be sufficient?
      www.E30S38.com
        • 34844
        dual pipes is mostly a looks/ground clearance thing, but GC isn't a big issue with 3". The old M3 DTM cars used like 4-4.5" exhausts.. lol
        yes, 3" is definitely enough :D
        • FredK
          • 14762
          The DTM cars also ovalized the tubing right under the subframe. :razz:
          However, you won't have a problem with ground clearance, a 3.0" exhaust, and a reasonably low ride height.
