torquing
  • NC325iC
    • Mar 2004
    • 6565
    torquing
    how the hell do you torque header/downpipe bolts
    • 37828
    You don't need to, just tighten the suckers
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Digitalwave
      is a poseur
      • 6286
      Yes you do, the only ones I don't bother torquing are the ones that connect the downpipes to the cat-back. All you need to do it get creative with extensions and a universal joint to torque the connections at the manifolds.
      RISING EDGE
        • 37828
        You do NOT need to torque the exhaust nuts, I don't care what any book says
        Grover Beach, CA
        www.BimmerHeads.com
        • NC325iC
          • Mar 2004
          • 6565
          well at the moment (after using an impact wrench) ive got exhaust leaking, ill go see what i can do about torquing them
          • BS87
            • 1606
            I don't know about manifold->head, but manifold-> downpipes i torqued the ~2 i could then the rest i just tightened to all hell. Works fine.
            • AndrewBird
              The Mad Scientist
              • 11898
              Torque wrenches are pointless. Ask any older GOOD mechanic and he will tell you he never uses/used a torque wrench. It's all about feel. It's tight when it feels tight, not when a wrench tells you it is.
              • zandi
                • Apr 2004
                • 602
                Yeah shit, I gotta go return my torque wrench cuz its a piece of junk
                • NC325iC
                  • Mar 2004
                  • 6565
                  sometimes tight to one person aka a weak ass person like myself is differnt, so a torque wrench makes it so you know when its tight
                  and sometimes tight might be too tight for a bolt. not using a torque wrench could result in a bolt snapping off.
                  • AdamF 88iS
                    • 2051
                    I will bet that the torque spec for those bolts is a lot less than what your impact gun did to them.
                    I'd take it apart and check the gaskets.
                    Adam Fogg- '88 M3
                    Common sense- It's the new 'gifted'
                    • Digitalwave
                      is a poseur
                      • 6286
                      Maybe for a master mechanic that has been doing it for many years. That is some terrible advice you are giving for the kids on this forum though.
                      RISING EDGE
                      • hamann318is
                        • 3382
                        I don't use a torque wrench on the oil pan bolt. I felt very nervous torquing down the head because the second two stages involve you going 90-95 degrees, and we had no real way to guess that other than the eye. Torquing is something that I would always try to do at least.
                        The BMW 318 is back. With a vengeance.
                        • zandi
                          • Apr 2004
                          • 602
                          Torquing is not needed unless you are working on engine related parts, otherwise, it's not neccessary.
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            Don't know if you noticed, but I'm a kid also. I've worked many hours and many cars (obviously not as many as some old-timers) and have never sheered a bolt off and have never had one come loose either.
                            And refering to what NC325iC said about sheering off bolts, its all in the feel. I can tell when a bolt is tight BEFORE it is anywhere near tight enough to sheer. It all depends though. Some people have the feel, others don't.
                            • zandi
                              • Apr 2004
                              • 602
                              Torque wrench is only 20 bucks, I don't see what the big deal is.
