How do I check if I have a blocked cat?
  • cello2119
    • Apr 2014
    • 69
    Hey my 85 318i bogs out at 4000rpm and seems to have a much larger gal between gear changes than other same model e30s I have driven. I reckon the reason could be a blocked cat. Do I have to take the whole exhaust from the headers off? Or can I just cut off the cat and then wield it or a new one back on?
  • MaxBell
    • 1391
    Just look through the tail pipe. If you can see light than there's no blockage! :)
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
    • cello2119
      • Apr 2014
      • 69
      Thanks man
      • 2mAn
        Señior Mod
        • 20857
        I highly doubt your problem is the cat... and I think the canadian was messing with you
        Simon
        Current Cars:
        -1966 Lotus Elan
        -1986 German Car
        -2006 Volkswagen Jetta TDI
        Make R3V Great Again -2020
        • rommaster2
          • Mar 2014
          • 89
          Generally a blocked cat will result in worse performance all across the board, like an engine that struggles to rev at all.
          Does it rattle? Every time i've dealt with a clogged cat it rattled like crazy and was clogged because a loose chunk got stuck in the output.
          • cello2119
            • Apr 2014
            • 69
            No it doesn't rattle, I changed both fuel pumps, AFM and injectors so I'm suspecting its the fuel pressure regulator now
            • cabriodster87
              • Jan 2011
              • 1042
              drill a hole ahead of cat, take pressure reading. any thing more than say 3psi is restricted.
              Reich und Roll!
              • Mike
                • 932
                Take a temperature reading
                Supatek -noun - your basic know it all
                • Swanny
                  • Mar 2012
                  • 2834
                  Xrays
                  If you love where they don't smog cut it the hell off anyway. Racecar.
                  Also, how is your timing and any vacuum leaks?
                  Swanny!
                  SUCKERS.
                  • Ether-D
                    • Sep 2011
                    • 2838
                    ^ Dammit, I was workin' a badass response on this order...
                    Originally posted by Andy.B
                    I was born on 3/25…
