Is a flex pipe really required?
  • MatRacer
    • 562
    Will work on my exhaust this winter since it is leaking very bad. The flex pipe is one of the guilty. The exhaust is a shitty 3'' for on a S50. Will clean and fix this mess.
    Is the flex pipe really required or I can just remove it and put a straight section?
    E30 now S52
    2008 Suburban LTZ (Family and TT hauler)
    325xiT (Sold)
  • Jaxx_
    • Dec 2009
    • 1880
    do you have solid engine mounts? Flex pipe is usually there to compensate for engine movement and not to rip the exhaust of the hangers.
    • MatRacer
      • 562
      no... S50 on e28 mounts...
      Also, if no flex pipe, can the induced load damage the manifold studs?
      E30 now S52
      325xiT (Sold)
      • digger
        • Nov 2005
        • 6122
        i havent had a flex mount since 2006/7 no issues on a custom stainless system. the engine/exhaust/gearbox are solid mounted together, the engine and gearbox are isolated with stock mounts and the muffler / exhaust is hung on the stock rubber mounts so everything is isolated and there is no mixing and matching of connections (solid mounts) and soft connections (rubber)
        • nomansland92
          • 1657
          When I bought my car with the stock exhaust it just had a slip over pipe where the flex used to be and it was clamped on for a little bit of movement, I welded it solid and ive broke the flange right after the stock manifold twice now. Going to use flex next time, also on stock mounts
          IX being restored here
          Ix turbo build here
