what kind/heat range of spark plugs do you use
  • bimmerboy08
    • Apr 2009
    • 353
    I've heard going 2 heat ranges colder is good for a boosted car, but since you guys are the boosted e30 experts I'll ask you. My car runs 8psi boost right now on the recommended heat range plug, but I need to change them out.
  • TS87325IS
    • Sep 2006
    • 821
    Iam still running stock coppers , but have only been boosted for about 2 months and don't daily my e30. but they seem fine still and i am running 7 lbs.
    mods: just meat and potatoes under the hood and wheaties on fire out back ;)
    • Danny
      • 14216
      Yep, 2 steps is fine.
      • bimmerboy08
        • Apr 2009
        • 353
        sweet thanks guys
        • bimmerboy08
          • Apr 2009
          • 353
          hey just for anyone searching in the future, I've got part numbers:
          for one heat range colder its NGK plug BPR6ES
          for two heat ranges colder its NGK plug BPR7ES
          bosch doesn't have plugs available for colder heat ranges.
            • 34837
            I'm planning on running BPR6ES with my stroker (been running OE bosch until now), for turbo I'd probably go for the 2 heatrange colder plugs.
            • bimmerboy08
              • Apr 2009
              • 353
              cool thanks, thats what I ended up ordering!
              • Madhatter
                • Oct 2004
                • 966
                in future its simply better to have a look at the state of your plugs. If they are too cold they will get sooted up and foul, especially if left sit for a period of time while idling. Just keep changing up a range until the plugs clear. Quite often you find you dont need much of a change at all.
                Just a little project im working on
                - http://www.lse30.com -
                • blueapplesoda
                  • Dec 2005
                  • 1904
                  I got tired of changing spark plugs...I dislike coppers.
                  hotter plugs idle better and help throttle response down low, but get overheated during prolonged abuse.
                  Stock NGKs would be bpr5es
                  I am currently using NGK BPR7EIX iridium plugs, 2 steps colder.
                  for the track, i use BPR8EIX, 3 steps colder
                  thumb of rule...for every 85-100hp increase, take 1 step colder.
