Max Rev limit with stock vavle springs?
  • syn52k
    • Feb 2017
    • 9
    I am looking to spin my motor a little higher. I have a m20b25 that i currently spin to 6800K at 17 PSI with mega squirt on a stock cam. I had recently sourced a brand new IE 272 cam that i am going to put in but thought about upgrading the springs while i am in there.
    Anyone have any recommendations or thoughts on stock valves with a 272 with forced induction? what is the highest i can spin with that setup? Should i upgrade my springs and if i do with a 272 what is the highest i can spin at? not sure if it matters much but i have a 3.73 rear.
    Thanks!
  • moatilliatta
    • 6136
    I don’t know the correct answer.
    But, stock I wouldn’t go past 7K, and consider a softer limiter.
    2nd, once the valve springs are done, you’re looking at doing the rockers too.
    3rd, is what’s the dyno chart looking like, is it worth it?
    @Zakspeed_US
    • syn52k
      • Feb 2017
      • 9
      I forgot to mention i have new IE rocker arms with the cam as well that will go in while doing the install. As far as dyno is sort the reasoning for the question.
