turbo help
  • drewpackard
    • Aug 2009
    • 22
    turbo help
    hey guys i have a 325is 87 i am looking to do a turbo.
    the only kits i can find are DIY kits and need to be taken to en exhaust shop and cut and molded.
    Does anyone know where i can find a kit that is made specifically for the e30?
    I want to keep it pretty cheap i might do an m50 swap very soon as well and dont want to spend more then 1500 on the turbo set up. what other parts and upgrades would i need for the turbo?
  • StereoInstaller1
    GAS
    • 22679
    If you want thing easy fast and cheap, you might want to consider buying a Honda.
    Closing SOON!
    Thanks for 10 years of fun!
    • drewpackard
      • Aug 2009
      • 22
      its not that i want it cheap and fast its that i might be doing the engine swap soon so if anything id want a turbo that i can use on the m50 as well
      • StereoInstaller1
        GAS
        • 22679
        Time for you to study a bit.
        AFAIK, no one make a prefab E30 downpipe.
        Closing SOON!
        • ethree
          • Aug 2007
          • 1216
          The 524td downpipe might clear the firewall?
          • StereoInstaller1
            GAS
            • 22679
            Are you thinking about doing a bottom mount?
            Closing SOON!
            • purebmw
              • 35
              DIY custom made is the only way
              e30 325i 1988 track toy
              e30 M3 1989 M106 motronic swap (in process)
              e36 M3 1995 S50B30 turbo
              e38 750il M73N
              Toyota Tundra 2UZFE (workshop car)
              BMV Motorsports Guatemala
              • DrFlathead
                • 42
                You need to do a LOT of research, and if you need to ask what parts and upgrades are necessary to turbo an engine your not even close to being ready to try it. An m50 swap is significantly more complicated and involved than turbocharging. Do the leg work and learn it inside out before you attempt it, and asking more specific questions will get you a better response.
                • einstein57
                  • Jun 2007
                  • 10780
                  sounds like you want the cxracing kit
                  www.gecoils.com
                  • Chabs
                    • Jan 2010
                    • 538
                    you can likely get an entire turbo kit on ebay.... wont be of the best quality but it'll include everything except downpipe.
                    and you'll have to do it yourself.
                    Josh
                    http://www.r3vlimited.com/board/showthread.php?t=159843
                    • lifeiskaos
                      • 1709
                      My turbo m20 was about $1500. I bought my H1C, 666fab manifold adapter, BOV, from the forums. Wastegate and intercooler/piping from ebay. I built the megasquirt myself. If you wait for deals, you can do it pretty inexpensively.
                      • blueapplesoda
                        • Dec 2005
                        • 1904
                        PLUG: http://www.r3vlimited.com/board/showthread.php?t=144652
                        :p:p:p
                        • SwiftE30
                          • Jun 2010
                          • 998
                          Hahahaha greatest quote of all time.
                          If your going to build an E30. Build it right, dont cut corners. They deserve it.
                          1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
