Starting a turbo build...
  • Rsully70sev
    • 2391
    Will this t3 turbo work on my m20 and why is it so cheap?????
  • Rsully70sev
    • 2391
    same with this one...
    • Rsully70sev
      • 2391
      Can someone shed some light for this noob please?
      • ForcedFirebird
        • Feb 2007
        • 8300
        Because that's a Chinese knock off. You can get them even cheaper on evilbay.
        john@m20guru.com
        Links:
        • Rsully70sev
          • 2391
          Makes total sense. How does it compare to the Garrett? Obviously it's far superior, but for just around town at 7-9psi, would it be worth saving th extra $600?
          • Dj Buttchug
            • Jun 2010
            • 7672
            do not do it. those turbos suck wang to the max. a used quality tarbo is what you need.
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • ForcedFirebird
              • Feb 2007
              • 8300
              I have used them without any mechanical problems, but beware that they are not what they are advertised as. I reverse-engineered one and found the journal bearings are the old Garrett type, and the impellers didn't match the trim levels they were supposed to be. With that said, no, they will not make near the power a Garrett will.
              john@m20guru.com
              Links:
              • Cyrix2k
                • 593
                Yes, and a real Super 60 would actually be a decent match for an M20 so long as you don't have extravagant power goals. As stated above, those particular turbos are cheap because they chinese crap.
                1997 540i/6 - stock
                1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
                1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
                • blueapplesoda
                  • Dec 2005
                  • 1904
                  they last 2 years or so, which by then they spool real slow and act funny and have shaft play and such.
                  but that crap makes 245 wheel at 8-9psi seems like almost any other turbo on the market...while they are fresh
