Turbo M20 Build
  • bobross
    • Jul 2005
    • 753
    #151
    Originally posted by trackstar
    awesome stuff. Cant wait to see the numbers
    +1000000000000000000000000000000000000
    -Greg
    90 325isT - 12.2 @ 120ish - Dyno Results
    b18c5 EG Coupέ - 13.5 @ 100ish - Dyno Results
    • beefjurky69
      • 613
      #152
      Got the head back a few days ago.
      It's all back together and all that's needed is bleeding of the coolant system. Need to check the head studs after a heat cycle then to the rollers.
      Build Thread
      http://www.e30tech.com/forum/showthread.php?t=84988
      "When In Doubt Boost It Out"
      ~89 325I Turbo 11.90 @ 121~
      ~ 420whp/420tq~
      15psi
      ~Paul Burke Built 2.8L Stroked M20
      ~666 Divided Mani T3
      ~6262 T3 Turbo
      ~O'ringed Block SS
      ~Custom Fuel System
      ~3'' Turbo Back
      ~50mm Tial Bov
      ~Dual Tial 38 Gates
      • kid325e
        • Sep 2007
        • 6421
        #153
        Nice! Everything looks great. Can't wait to see what it puts down!
        clutchCTRL!
        Move with a purpose.
        - 1991 325iX 4dr/5spd
        - 2000 323i AT
        2016 Mazda CX3 Sport AWD
        • beefjurky69
          • 613
          #154
          Thanks man...drove it around town and sounds better than ever. Should have it tuned by the end of the month.
          Build Thread
          ~ 420whp/420tq~
          15psi
          ~6262 T3 Turbo
          ~O'ringed Block SS
          ~Custom Fuel System
          ~3'' Turbo Back
          ~50mm Tial Bov
          ~Dual Tial 38 Gates
          • bobross
            • Jul 2005
            • 753
            #155
            So pumped for this build. Is that a 6262 t3 or t4? journal or dbb?
            When are you seeing 10 psi on the street?
            -Greg
            • FLG
              • Sep 2011
              • 3165
              #156
              Looking good...I saw a Fram oil filter in your first post.
              Please get rid of it before it fails and kills your motor or explodes. Hands down the worst filter manf out there. Go with wix if they make one or mobile, mahle...just ditch the fram.
              Sent from my Galaxy Nexus using Tapatalk 2
              -Build http://www.r3vlimited.com/board/showthread.php?t=295277
              • beefjurky69
                • 613
                #157
                6262 t3 journal bearing...did the journal for longevity of the turbo. I'm seeing a steady 10psi on the street.
                Yea the Fram was on there just to stop oil from leaking and to prim the engine. I'm running a Mobil 1 and always will.
                Build Thread
                ~ 420whp/420tq~
                15psi
                ~6262 T3 Turbo
                ~O'ringed Block SS
                ~Custom Fuel System
                ~3'' Turbo Back
                ~50mm Tial Bov
                ~Dual Tial 38 Gates
                • Snou52
                  • Nov 2011
                  • 176
                  #158
                  dude, it's been said before, but this is an intense build! lol subscribed for more updates!
                  quick question, do you have specs on the intercooler...i know you gave the diamensions, but was wondering if you had the exact brand or part number? also how much cutting was needed to make it fit?
                  i'm trying to keep both headlights, and keeping the front bumper looking stock with the fog lights and brake ducts, but i would like to see the intercooler in the bottom middle, just like how you have...any info on the intercooler would help. thanks!
                  1988 325is 237k
                  • beefjurky69
                    • 613
                    #159
                    Thanks alot man...the Intercooler size is 30x12x3 that's from end tube to end tube. Had to cut the from rail a little.
                    Build Thread
                    ~ 420whp/420tq~
                    15psi
                    ~6262 T3 Turbo
                    ~O'ringed Block SS
                    ~Custom Fuel System
                    ~3'' Turbo Back
                    ~50mm Tial Bov
                    ~Dual Tial 38 Gates
                    • beefjurky69
                      • 613
                      #160
                      What's up guys...so I'm back after a long break...while I was gone a few things happened I got married and I got a built motor. Here's a shot of the Ferrari my brother rented me as a wedding gift.
                      So on to the built motor specs
                      M20 2.5 with .020 over wiseco pistons
                      Stock rods
                      Stock crank
                      Entire bottom end has arp hardware
                      Head built by Vac
                      Welded coolant passages
                      Vac dual valve springs
                      Vac billet rockers
                      Schrick 288 cam
                      Stock valves
                      Vac adjustable cam gear
                      Also got a new fuel system...stock tank with dual walbro 255's
                      Aftermarket fuel rail. Stainless hard lines under car for E85. Custom 2 piece steel/aluminum driveshaft. I'll have pics of the driveshaft soon.
                      I ran the car on 10 psi so far on my last tune that I made 380whp with. Feels good and the respond with the new came is ridicous. Holding steady at 10.5 afr going back for a fresh tune on pump gas and also retuning my timing map. I plan on making a second map for E85. I'm hoping to break 500 on pump and see what I can do on e85.
                      Right now I have the subframe out waiting on some revshift riser bushing,diff bushing and rtabs. Will post pics soon on that.
                      Here's a small video on the engine idling
                      Enjoy
                      Build Thread
                      ~ 420whp/420tq~
                      15psi
                      ~6262 T3 Turbo
                      ~O'ringed Block SS
                      ~Custom Fuel System
                      ~3'' Turbo Back
                      ~50mm Tial Bov
                      ~Dual Tial 38 Gates
                      • sayed ali
                        • 762
                        #161
                        Awesome! :)
                        M20B28 Turbo
                        My Build Thread
                        http://www.r3vlimited.com/board/showthread.php?t=255839
                        • jmerck0215
                          • May 2012
                          • 38
                          #162
                          Subscribed! Awesome thread. It just keeps getting better :)
                          '91 e30s50
                          • Cronopoulos
                            • Jul 2011
                            • 2187
                            #163
                            That sounds wicked, nice work!
                            Project log -- DIRTY 30
                            2.7i * Megasquirt tuned * E85 powered
                            • Simple_Smith
                              • Aug 2011
                              • 585
                              #164
                              Ugh so jelly. I cannot wait until I have the funds to copy you haha. Awesome work so far
                              1989 JDM-Tech 2
                              2010 335 D for daily
                              • beefjurky69
                                • 613
                                #165
                                Thanks for the kind words guys...here are a few pics of the custom drive shaft
                                Rear section going to diff
                                Front section to Trans
                                Build Thread
                                ~ 420whp/420tq~
                                15psi
                                ~6262 T3 Turbo
                                ~O'ringed Block SS
                                ~Custom Fuel System
                                ~3'' Turbo Back
                                ~50mm Tial Bov
                                ~Dual Tial 38 Gates
