"When In Doubt Boost It Out"
~89 325I Turbo 11.90 @ 121~
~ 420whp/420tq~
15psi
~Paul Burke Built 2.8L Stroked M20
~666 Divided Mani T3
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
Looking good...I saw a Fram oil filter in your first post.
Please get rid of it before it fails and kills your motor or explodes. Hands down the worst filter manf out there. Go with wix if they make one or mobile, mahle...just ditch the fram.
Sent from my Galaxy Nexus using Tapatalk 2
Yea the Fram was on there just to stop oil from leaking and to prim the engine. I'm running a Mobil 1 and always will.
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
dude, it's been said before, but this is an intense build! lol subscribed for more updates!
quick question, do you have specs on the intercooler...i know you gave the diamensions, but was wondering if you had the exact brand or part number? also how much cutting was needed to make it fit?
i'm trying to keep both headlights, and keeping the front bumper looking stock with the fog lights and brake ducts, but i would like to see the intercooler in the bottom middle, just like how you have...any info on the intercooler would help. thanks!
Thanks alot man...the Intercooler size is 30x12x3 that's from end tube to end tube. Had to cut the from rail a little.
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
What's up guys...so I'm back after a long break...while I was gone a few things happened I got married and I got a built motor. Here's a shot of the Ferrari my brother rented me as a wedding gift.
So on to the built motor specs
M20 2.5 with .020 over wiseco pistons
Stock rods
Stock crank
Entire bottom end has arp hardware
Head built by Vac
Welded coolant passages
Vac dual valve springs
Vac billet rockers
Schrick 288 cam
Stock valves
Vac adjustable cam gear
Also got a new fuel system...stock tank with dual walbro 255's
Aftermarket fuel rail. Stainless hard lines under car for E85. Custom 2 piece steel/aluminum driveshaft. I'll have pics of the driveshaft soon.
I ran the car on 10 psi so far on my last tune that I made 380whp with. Feels good and the respond with the new came is ridicous. Holding steady at 10.5 afr going back for a fresh tune on pump gas and also retuning my timing map. I plan on making a second map for E85. I'm hoping to break 500 on pump and see what I can do on e85.
Right now I have the subframe out waiting on some revshift riser bushing,diff bushing and rtabs. Will post pics soon on that.
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
