Well here we go finally started my turbo build. Looking on making around 350hp/400 would be awesome. My platform is an 89 325i with 79,000 miles Florida car. Here are a few pics let me know what u guys think.
Turbo M20 Build
Turbo M20 Build
Build Thread
http://www.e30tech.com/forum/showthread.php?t=84988
"When In Doubt Boost It Out"
~89 325I Turbo 11.90 @ 121~
~ 420whp/420tq~
15psi
~Paul Burke Built 2.8L Stroked M20
~666 Divided Mani T3
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 GatesTags: None
Got the valve cover and intake manifold sand blasted and painted at my job
Here's a few pics of some parts and hardware
Few pics of the VEMS engine harness
Heres a few pics of the fabbing I did...intercooler pipes and exhaust wrap
The oiling system and suspension
I'm almost done with the build here's a few pics of when I got the car and how it sits now...still have to install a clutch finish the VEMS harness and tune the thing
Before
After
Enjoy thanks for looking
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
Originally posted by akw_ View Postwow nice build!
how big is your intercooler? im realy liking the look of the cooler piping
Originally posted by Danny View PostInteresting wastegate routing...
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
Originally posted by IRON-E View PostI'm really digging the TARBO e30 influx we've had lately, I might have to start looking for an SETA engine and collecting parts like a squirrel.
Nice build.
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
Very clean install. Wish i had your welding skilz. As far as the wastegate the outlet should have a flex pipe to allow for thermal expansion right? Considering how long your plumbing is, its probably going to have all kinds of internal stress.
Last edited by einstein57; 10-10-2010, 10:01 AM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
Originally posted by einstein57 View PostVery clean install. Wish i had your welding skilz. As far as the wastegate the outlet should have a flex pipe to allow for thermal expansion right? Considering how long your plumbing is, its probably going to have all kinds of internal stress.
It could completely back fire on me and crack but im hoping by running poly engine and trans mounts i shouldn't get to much movement to crack the welds (im hoping) i guess time will determine that if it cracks than i'll put one. if i dont need one i rather not use one cause they look pretty ugly especially up top where everyone can see it
Thanks for the comments i been practing tig welding for over a yr just about everyday its hard when you first start but once you have a flow its just like everything else it just gets easier...i also fabricate at maximum psi for a living so being around it everyday also helps alot
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
The factory exhaust does have a flex section in one of the down tubes. Its more about expansion then flex and considering that the wastegate only has gases flowing through it breifly it won't be nearly as hot as the rest of the down pipe. So the likely hood of a crack developing are great. Especially if you use stainless. And the longer the wastegate plumbing the more likely it is to crack.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
Originally posted by einstein57 View PostThe factory exhaust does have a flex section in one of the down tubes. Its more about expansion then flex and considering that the wastegate only has gases flowing through it breifly it won't be nearly as hot as the rest of the down pipe. So the likely hood of a crack developing are great. Especially if you use stainless. And the longer the wastegate plumbing the more likely it is to crack.
Originally posted by azael325i View PostOMG I like great job
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
No flex you will be fine. I don't have a flex on my wastegate tubing, internal stress can suck it.
Then again, I made my wastegate plumbing as short as possible to minimize thermal expansion...of course at the cost of slight turbulence of exhaust stream. After the wbo2 and the egt sensor of course..
Nice build, good choice on EMS.
Thanks guys...here are a few vids of the car running finally she's up and going. Just a few more things left and off to the rollers. Also a few updated pics of the car.
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
