Why does my Boost fall?
  • Lrutts
    • 104
    What are the reasons that could cause my boost to hit 8psi then fall to 6 or 5 almost right away? I have an internal waste gate.
    Too small? Blood Sweat and Tears Build:
    http://www.r3vlimited.com/board/showthread.php?t=202389
    • 37829
    Leaky wastegate. Leaky boost pipes. Leaky BOV.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Dominic49
      • Feb 2007
      • 1373
      wastegate lag whats is the wastegate set to?
      exhaust piping, manifold design, there is alot of things at work here.
      • bmw335isturbo
        • Mar 2006
        • 218
        Originally posted by mr 325
        leaky wastegate. Leaky boost pipes. Leaky bov.
        +1
        1986 335is-1988 335ist -1991 335istsigpic
        • Toadleg
          • May 2011
          • 209
          sounds like a boost leak test is needed. In my experience if you look at your car wrong you will get a boost leak
          • Lrutts
            • 104
            Haha i would agree, ok thanks guys. I had a feeling that it was one of those things, but i figured i should ask incase there was something i missed. I will go tighten things up and then go from there.
            Whats the best way to test for a leak?
            Just doing the whole block off both sides and use an air compressor?
            • Toadleg
              • May 2011
              • 209
              On one of my cars I take the intake off the turbo and attach to that With whatever works for you size intake. For me it was a 2 inch mission band with pvc cap and thread in a schrader valve. Get a compressor and pump it up and you will hear the leaks or spray soapy water on pipes and bubbles will appear. You will have to cap off a couple lines that will just leak air I dont know your set up mine is one of those turbo neons.
              • Toadleg
                • May 2011
                • 209
                Try and get it to hold 15lb for as long as possible you will get some leak by in the head
                • Toadleg
                  • May 2011
                  • 209
                  On my car i switched to an external waste gate and that seemed to help with boost spike also
                  • sweet6e30
                    • Feb 2011
                    • 531
                    classic boost leak
                    my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
                    • ak-
                      • 12422
                      Are you able to hear any faint rattling during boost?
                      1991 325iS turbo
                      • Lrutts
                        • 104
                        No it sounds fine, i can't even hear a wine or anything like that. I went to home depot to get the stuff i need to make a home made boost leak test kit, they had nothing.....
                        • einstein57
                          • Jun 2007
                          • 10780
                          Whats yor wastegate supposed to be set to?
                          www.gecoils.com
                          • Lrutts
                            • 104
                            8psi, ebay turbo
                            • euro2fast4u
                              • 545
                              what size ebay turbo?
