Why does my Boost fall?
  • Jaxx_
    • Dec 2009
    • 1880
    could just be the shit internal wastegate. Unplug the wastegate's line and really slowly roll into the throttle to see if there's a leak. If you can boost 8psi and you're not losing boost, your internal wastegate sucks, just like all internal wastegates. And this way you don't need to worry about pressure testing.
    • euro2fast4u
      • 545
      i feel like that just sounds like a bad plan. why not take the time and do a boost leak test. i still think its just too small of a turbo.
      • Jaxx_
        • Dec 2009
        • 1880
        because it takes 5 seconds and free vs many trips to a hardware store and a few bucks...
        It's perfectly safe as long as you're sensible. and that also gives you an idea of boost fade.
        • Lrutts
          • 104
          That could work, i already have most of the stuff to do the leak test, so i might do that. But i would bet that its a shit waste gate as well, i will prob switch to external right away. Should i just weld the internal shut?
          Too small? Blood Sweat and Tears Build:
          http://www.r3vlimited.com/board/showthread.php?t=202389
          • Jaxx_
            • Dec 2009
            • 1880
            or you could preload it to a very high amount so that you can still have the extra room if your external can't do the work.
            But I would just wire it shut as long as it's sealing properly. No need to weld it. Even better: replace the exhaust housing with no wastegate. ;)
            if your boost is fading after a few seconds, likely a wastegate and boost control issue. If you see it fall off even more near redline, it's for sure a wastegate issue. Seriously, just pull the wastegate vac line and go for a drive. take it real easy getting up to 50mph and put it in 3rd/4th gear. roll into the throttle and watch your boost gauge. do a few pulls for consistency. Drive carefully home and re-connect your wastegate line. don't even think about going WOT unless you are in a tall gear and low RPMs. but always ALWAYS roll into the throttle and not stomp on it. It's a simple troubleshooting test. I daily drive a turbo car and I've had 2 more. my E30 is my first non-turbo car.(and I have a turbo in my room to fix that)
            • euro2fast4u
              • 545
              report back your findings
