I need a Turbo Manifold for my 87 e30 325i !!!!
  • kreaglewon
    • Jul 2010
    • 27
    I'm looking for a e30 turbo manifold with a wastegate port.
    Does anyone know where I can get a good one ?
    Please send me a pm if so.
    Thanks !!!!!!!!!!
  • Good & Tight
    • Apr 2004
    • 2057
    24V or M20..?
    Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
    ____________________________
    E-mail Panayiotisx2@gmail.com
    Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
    • z31maniac
      • 17566
      If 24v, I'd go with ^^^^^^
      If M20, I'd likely go with a TCD (www.turbochargingdynamics) bottom mount. Which is what I am going with on my next build.
      www.gutenparts.com
      • einstein57
        • Jun 2007
        • 10780
        M21 will do as well.
        www.gecoils.com
        • The Humjet
          • Jun 2010
          • 528
          Run an adapter, good quality and cheap and has a external gate outlet
          • MonkeyMadness
            • 3251
            true that!
            • Rc 415
              • Jun 2011
              • 723
              Any reason in prticular you'd go tcd bottom mount?
              1987 Delphin 325IS
              LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
              Build Thread
              1993 alpine 2 325IC
              •Ground control coilovers•16" BBS RS• momo woodgrain
              • einstein57
                • Jun 2007
                • 10780
                To make your life harder. Lol. But it does look good once its in there. Check out my build thread for more info. I used a bottom mount out of stubborness. Next build will be from schedule 10 mandrell bent stainless tubing. Probably bottom mount as well.
                www.gecoils.com
                • Rc 415
                  • Jun 2011
                  • 723
                  Is it a pain in the ass to use the bottom mount?
                  1987 Delphin 325IS
                  Build Thread
                  1993 alpine 2 325IC
                  • euro2fast4u
                    • 545
                    just requires extra work, might need a pump for the oil return line, have to modify the motor mount, just more difficult but is very possible
                    • KenC
                      King of Kegstands
                      • 14396
                      You can probably still keep AC with a top mount.
                      Originally posted by Gruelius
                      • einstein57
                        • Jun 2007
                        • 10780
                        www.gecoils.com
                        • kreaglewon
                          • Jul 2010
                          • 27
                          Turbo manifold....
                          I was told that the TCD manifold will not allow the turbo to spool up as quickly as the design that cx racing makes....anyone have any input or a reason why ?
                          • MonkeyMadness
                            • 3251
                            First off what's your objective?
                            Daily Driver, Drag, road track,
                            What's your hp objective?
                            What turbo?
                            Rev range?
                            • einstein57
                              • Jun 2007
                              • 10780
                              I have a TCD and my buddy just turbo'd his car with the cx manifold. Considering my T4 is larger then his t3/t4 its only a difference of a couple hundred RPM.
                              www.gecoils.com
