car is running great haven't been boosting at all until i get my wide band in 2 weeks, went to work this morning and its only to blocks away, car ran great this morning too, i come out from work and all the sudden it has a huge miss, all injectors are new and properly hooked up, all the plug wires are in good shape i let the car run why i pulled each plug 1 by 1 at a time and it made no difference, anyone got any ideas?
turbo the e30, now cut out when shifting?
Coolant temp sensor, blown headgasket, burnt/broken valve, hole in piston. Did it throw a CEL?Last edited by Hey_You; 09-07-2011, 04:39 PM.Comment
Could be a failing fuel pumpComment
it started acting normal normail again the next morning, just put the rising rate on yesterday, rinning better, dyno in 1 monthComment
It's lurking in the depths! Don't worry, it will show it's face again in the future.Comment
you should atleast do a video of acceleration inside the car with the tach and speedo. im smelling a big fishComment
Dude, you're an idiot. That's coming from a 18 year old.
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.Comment
