Dumb Ass Teenager Turbo/Body Work/Respray Learning Experience Build Thread
You won't need a full 3" exhaust system for 7psi but a 3" DP will help out a lot. And as far as your goals I take it you mean 320 crank. I sell oil feed blocks that are very similar to the TRM units. Mine are cad plated mild steel so they are half the price. I'd look in to a used PNP megasquirt unit if your car is NV. They can be had for pretty cheap or you could always build one yourself. That will eliminate the maf and aftermarket fpr. But I'm sure the general concensus will be to buy a TRM tune.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
Even if you prefer this community, which I do as well, e30tech really is the place to ask these questions. There is a hell of a lot more info there. You could find the answers to all of your questions simply by looking through Jordan's massive thread. I'm not trying to be a dick, I am just stating the facts.
Oh I understand. That thread is gold.
Yes
Im far more concerned with getting a running and reliable setup then getting a certain number.You won't need a full 3" exhaust system for 7psi but a 3" DP will help out a lot. And as far as your goals I take it you mean 320 crank. I sell oil feed blocks that are very similar to the TRM units. Mine are cad plated mild steel so they are half the price. I'd look in to a used PNP megasquirt unit if your car is NV. They can be had for pretty cheap or you could always build one yourself. That will eliminate the maf and aftermarket fpr. But I'm sure the general concensus will be to buy a TRM tune.
Swap was done by PO (Although Ive had the motor out several times)
Hopefully I can go that route.
There is no chip turbo tune for the NV engine. I would look into megasquirt for tuning.Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=ULComment
With out a tune your basically leaving the fate of your engine up to the effectiveness of the factory knock sensor. A war chip will allow you to pull a few degrees of timing yourself and make adjustments for the larger injectors. You can probably find some general m50 base maps on e30tech.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
