6 degree cam advance preventing motor from revving past 2,500??
  • Dublbass_monster
    • Nov 2011
    • 23
    Am I just a total idiot? Or what? Turbo M20, no wideband, O2 sensor still hooked up, MAF not adjusted, 6 degree cam advance. Car doesnt rev past 2,500, I cant get a direct answer on how much fuel pressure I should have as I have an adjustable fuel pressur regulator, runnign 24# injectors, anyways, I also havent adjusted my AFM and every thread i take time to read is a bunch of BS about the M30 AFM not the M20 AFM, How do I adjust the M20 AFM???? Obviously it would best be done with a wideband but I know what a car smells like rich so im not scared to foul a set of plugs messing around. What I'm wondering is why it seems like I'm hitting the rev limiter at 2,500 RPM, ANY INSIGHT IT GREATLY APPRECIATED THANKS ~Winston~
    • 34844
    6 degrees is a huge amount.
    • digger
      • Nov 2005
      • 6196
      i would be suprised if 6 degrees caused those symptoms
        • 34844
        Me too but its still a lot :(
          • 37833
          It's probably rich at low RPM and leaning out when it revs up. Severe lean will make it not rev.
          Advanced timing plus boost is not such a great thing.
          Grover Beach, California
          BimmerHeads.com
          • jaywood
            • Jul 2010
            • 4528
            You adjust the afm wheel by turning the wheel under the black cap either clockwise or counterclockwise. This is the wheel to turn:
            It's under the cap that has the sticker on it:
            The cap is a bitch to pry off.
            I doubt that's your problem though
            • LowR3V'in
              • 4209
              Did you make another user name?
              • jaywood
                • Jul 2010
                • 4528
                Originally posted by LowR3V'in
                Hahahah!
                • blueapplesoda
                  • Dec 2005
                  • 1904
                  Try taking the compressor outlet hose off and putting the stock injectors back. Then see if it'll rev past 2500.
                  Read e30tech, search; stop reposting your problems.
                  Post pictures of everything.
