What wastegate to go with ?
  • Exodus_2pt0
    • 5943
    a Tial 38mm should do the trick. Had one with a gt3071r at 23psi and never had any issues.
    But a 44 can't hurt. ;)
    No E30 Club
    • Good & Tight
      • Apr 2004
      • 2057
      I small wastegate like a 38mm will not work well if yo want to run 10 or less psi. It can't release enough exhaust which will result in boost creep. Higher boost is fine like 15+psi but anything lower you want to run a bigger wastegate.
      Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
      ____________________________
      E-mail Panayiotisx2@gmail.com
      Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
      • sayed ali
        • 762
        Originally posted by SwiftE30
        nice work!
        dont you feel kind of dirty/impure having japanese parts in your german motor though? hahaha
        I think it's a cheap/good replacement of getting forged pistons $$$
        Originally posted by ak-
        With a motor like that why don't you get something proper for tuning??
        As for now I'm staying with this and it's working fine, but to get Megasquirt is my dream :D
        Thanks alot,
        So 44mm seems to be the best for me now
        M20B28 Turbo
        My Build Thread
        http://www.r3vlimited.com/board/showthread.php?t=255839
        • Exodus_2pt0
          • 5943
          Touche, never dealt with such low pressures. :D
          No E30 Club
          • SwiftE30
            • Jun 2010
            • 998
            sounds like tial 44mm is the one to go with. thanks for the info. I wasnt aware that the 38mm had to be used for 10+ hp. i only want to be around 6-8psi at first to see how the motor holds, then creep up to around 12-14psi.
            1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
