turbo injectors selections!
  • dirty thirty
    • 372
    what is the most common injector used of a turbo m20.
    My build is a 2.7i with a stock eta bottom end and a ebay turbo kit,im goin with the dms ems system form blueapplesoda and he is saying my # 19 injectors are to small.
    i did some searching and found # 24 mustang injectors , but whats years mustang do they come out of 4.6 5.0?
    im only looking to get 300whp max , nothing to crazy !!
    what are you running!
    thanks
    Just out trying to build some boost !!
    Stroked and blown 328i @ 15psi
  • dirty thirty
    • 372
    whos running 42 lbs from ford out of a 5.4 supercharged
    • sayed ali
      • 762
      42lbs should be fine for 300whp
      M20B28 Turbo
      My Build Thread
      http://www.r3vlimited.com/board/showthread.php?t=255839
        • 37833
        When you're using MS you want to run large injectors. It's better to run a big injector at less duty cycle than a small injector at 100% duty cycle. I also have one of the DMS kits and Derek recommended I buy 42lb injectors which I am running now.
        Grover Beach, California
        BimmerHeads.com
        • dirty thirty
          • 372
          why is this ? you the injector isnt working so hard ?
          • dirty thirty
            • 372
            42lbs out of a 5.4 supercharged ford lightning are here, dms ems kit earlie next week
            • codrum
              • Jan 2011
              • 279
              Injectors aren't meant to run at 100% duty cycle, you risk running into lean spots in your tune when atmospheric and other conditions change. Definitely err on the side of caution on this one and get decently sized injectors: 42lb/hr.
              • Dj Buttchug
                • Jun 2010
                • 7688
                as earlier stated bigger with ms is better. im running 970cc injectors on my m42 setup
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • codrum
                  • Jan 2011
                  • 279
                  970cc is really large, how much boost are you running to require those? Don't forget if you go too big you lose tuning resolution in the lower RPMs and the idle can be hell to get right.
                  • dirty thirty
                    • 372
                    cc - lbs per hr what the conversion math?
                    • codrum
                      • Jan 2011
                      • 279
                      It's roughly a multiple of 10.5: 42lb/hr = 440cc
                      • dirty thirty
                        • 372
                        thanks!
                        • Kvasi
                          • Apr 2011
                          • 1122
                          On an 6syl you need atleast the same cc injectors as engine horsepower. 300 HP -> 300cc injectors, or bigger.
                          Going E85, add 40% injectorsize.
                          • dirty thirty
                            • 372
                            and is this fact or rule of thumb , 42lbs = 440 cc roughly . 440whp would be the most power i can put down ever? what about being boosted or nitrous?
                            • Q5Quint
                              • Jan 2005
                              • 725
                              http://www.megamanual.com/v22manual/minj.htm#size
                              Note: I think this oversizes injectors a little bit. If your car comes with 14s and this equation tells you to use 17s with 175 hp....safe side.
                              I was hitting 64% duty cycle on 24s at 7.5 psi... 80% is the high mark so its getting close. If you are trying to go for 10psi and up you will want bigger injectors than the stock moronic can handle although some folks manage to make 32lbers work in there with a rrfpr and a lower start fuel pressure to keep the idle right and not run out of fuel under boost.
